I am looking to buy a newer 911 (newer then my 1990 C2). I live in one of the hottest areas of Arizona so an A/C unit that cools the interior quickly is an important consideration. Can anyone provide some info on when and if Porsche installed more powerful A/C units? Thanks for any help.
Early 90 C2 Cab |
If you can get to Patrick Motorsports they can help. I was referred there by another company ACKits also in Phoenix. You are lucky to live near either of these companies regarding AC issues.
There is a thread running describing improved condensers for some models of 911, this might also help but I would check with Patrick Motorsports first. |
"...when..more powerful...A/C..."
With the advent of water cooled engines... |
I read starting with the late 89 - 964 4wd had much better AC, it is an interesting subject, how the AC works, what is weak, what needs to be done to convert/etc. AC performance seems to be very mysterious, but it probably doesn't need to be. I made another diagram, may post somewhere here. I'm looking for the on-going AC "education" thread.
Thanks for the quick responses. I'll give Patrick Motorsports a call and see what they would propose. The original compressor has been checked and meets specs: the system holds pressure. I have a second (928) condensor with fan already installed. Had to sacrifice the rear seats to fit it in. I'm attaching a photo of the installation. I also "summerize" the car by putting in 1" foam rubber as an extra headliner. I'd be a little concerned about a different compressor. Additional drag on the engine from both engine heat and effect on all the computer settings (idle speed ect.) plus a higher pressure system that may require replacing lines and fittings. I'll see what they have to say but leaning more towards a newer model car where the factory has soved my problem.
Early 90 C2 Cab |
964 much better than my 88, 993 even better but don't think they really got it right till the 996 series which has great a/c.
You can upgrade the anemic factory system with additional condensers, better evaporators, more powerful fans, etc. Several aftermarket shops provide A/C upgrade parts specifically for the 911. Why limit yourself to what came from the Porsche factory?
SOLD: '87 Carrera |
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Here's the simple answer. It worked for us. Rennaire 1-830-522-0300
1986 911 Targa. Per Road and Track magazine: Only in L.A.: In the window of a bar in Hermosa Beach, California. "Happy Hour prices during all car chases." |
Request for quote: R12 to R134a
Car: 89 3.2 Coupe 1 - Sanden 507 Compressor 2 - Bracket for Compressor 3 - full barrier hose kit, all seals/etc. 4 - new receiver dryer 5 - better rear condenser (micro channel?) 6 - better front condenser (micro channel?) 7 - over/under pressure switch 8 - correct expansion valve (assume evaporator is good enough) 9 - inline filter(s) to protect expansion valve and/or compressor 10 - mechanical install instructions, will take to shop or your shop for filling if within reasonable driving distance 11 - oil if doesn't come in the compressor options: 12- new evaporator Parts are to be bolt up compatible or easy modification, e.g. no front condenser hanging down, fits in the stock space. What is wrong with this kit? Adds? I don't want to add condensers e.g. under fenders/etc. I feel like better design condensers available now compared to 25 years ago or more should get the performance needed. Max. dry bulb 103F. |
if you have a 964 c2 you have the best a/c for an aircooled car
1973 911S (since new) RS MFI specs 1991 C2 Turbo |
if you=me then no I don't have a C2 I have a 3.2 Carrera, C2 not available until 90 or 91 I think, my AC isn't good originally was R12 and I want to switch
I think you mean a second "evaporator" in the rear
![]() 911 C2 Turbo Look ![]() Harley Fat Boy ![]() Jeep TJ Sporttrac Adrenalin![]() 911 SC(sold) Sporttrac(sold)
Or you can have an A/C specialist convert your car to r134 for less than $200. Make it ~$500 and you will get a Hi/lo pressure switch, a new rcvr/dryer, AND 2 9" radiator cooling fans to force airflow over the rear condensor whenever the compressor cutch is engaged. You can then discard the horribly inefficient front condensor blower mower, and maybe even the front condensor. |
I bought and installed this kit from Rennaire about 5 years ago, (our host didn't carry it then) and installed it myself over a couple of weekends. Yes the front condensor is thicker, but i used a couple flat washers as spacers so it doesn't stick out below the crash bar. It has the serpentine evaporater with a 134A expansion valve, serpentine front condensor, procooler (that functions as an additional condensor) Sanden 507, adapter plate and the barrier hoses of the proper length with correct fittings, all o-rings and compressor oil. Back then it didn't come with a pressure switch but I asked for one and he threw it in at no extra cost. Not sure if it's included in the kit now, but if not they are readily available. The only stock piece of my system left is the decklid condensor. I also have not added any additional fans on the condensor. I'm very happy with results. When its 105+ here I can get upper 40's vent temps which, while not as good my Chevy truck, is still pretty comfortable. When I did the upgrade I considered the Griffiths kit, but this one was less expensive and seemed to be more of a drop in replacement.
1986 Carrera Coupe 1999 Chevy Tahoe 1987 Chevy Blazer 1955 Chevy Apache 3100 Pickup "A little knowledge is a dangerous thing" |
Yes, that's quite a BARGAIN, RennAire Kit for $1500.00 plus HOURS to install vs.....
$36.00
I've an '89 that's completely stock, as to it's AC and budget allows only small patches at this point....(happen to be working in the suspension area for now)...soon, she'll get these fresh AC pieces mentioned in this thread.
There certainly is a cleaning process (flush) that can be done to the condensors. I kinda' wished that I had done that as part of my recent work, but didn't. We only pulled vacuum/verified hold ,..then load the R-12. I still can't hit the vent temps that others hit on the stock units, completely relative to environment (i.e., on a 78 degree morning , that AC will provide me 43 degrees (quite cool)...but on the +100 degree days, she struggles to get 60 degrees at the vent,..sometimes giving me mid-50's. So, I'm sure others will chime, but my approach would be to excise "all" of that dreaded system if you're gonna' do it....(whole-hog). Newer condensor designs are a bit better at what they do (not to mention the age of what's "in-there" (reliability),..so....If it were me, I'd address the WHOLE shooting match. So, the red fans (above) fit nicely on the rear (tail) condenser of an '89? If so, I'll order these pups tonight. Great price. I've always wanted to add this kit "type/style", albeit with marginal improvements in many cases-so I've heard. BUT: IMPROVEMENT, NONETHELESS!!!!!!!!!! Other interests would be how the plastic (?) handles heat over the long haul... Will have to search for install pics... Thanks! Doyle
Recording Engineer, Administrator and Entrepeneur Designer of Fine Studios, Tube Amplifier Guru 1989 Porsche 911 Carrera Coupe 25th Anniversary Special Edition Middle Georgia |
ALSO: some good reads at: I make Parallel Flow Micro-Channel Condensers for 911's front and rear
BEST! Doyle
I added the ebay fans to my 76. It helps but had to do some intake cover mods to get the pax side to fit. Does well to about 93 F. Thinking about tinting the targa window might help a little more.
Any pics of your "mods" for fitment? I'm looking for fans that drop in without any concerns for fitment (again, on a '89)
Thanks, Doyle
