Member 911 Anonymous
DRACO A5OG's Avatar
Frozen Screw for Rear Rotor Head Screw
Hey Fellas,
Stuck. Literally.
Both of my right rear per PAG "Head Screws" are frozen, soaked in PB blaster, tried heat, tried hammering on them. No Go
Does anyone have a technique on removing frozen screws in particular the rear rotors? Except drilling them out or chiseling the head off???
TIA,
Jim
'85 Carrera Targa
PCA/POC
Old 07-21-2011, 06:47 PM
abit off center
cgarr's Avatar
Did you try an impact screwdriver?
______________________
Craig
G2Performance
Old 07-21-2011, 06:50 PM
Harbor Freight has a nice impact screwdriver with 4 bits that will get them out.
Old 07-21-2011, 06:52 PM
DRACO A5OG's Avatar
No, but was on my way to get one. Air or will battery operated do?
'85 Carrera Targa
PCA/POC
abit off center
cgarr's Avatar
Hammer impact
Craig
G2Performance
DRACO A5OG's Avatar
"Here I come to save the Day, Mighty Mouse!" I just heard that in my head when I saw your post.
Thanks for the lead, both of you
Jim
'85 Carrera Targa
PCA/POC
Old 07-21-2011, 06:53 PM
One of these:
1986 911 Carrera Coupe
2016 VW Golf R
2008 Toyota Highlander (given to kid)
2021 Kia Telluride
2020 BMW R1250RS
Old 07-21-2011, 06:54 PM
Platinum Member
dad911's Avatar
Nope, the kind you hit with a hammer: Harbor Freight Tools Impact Screwdriver Set with Case 37530
Old 07-21-2011, 06:55 PM
DRACO A5OG's Avatar
Originally Posted by cgarr View Post
Hammer impact
I tried that with my Screw Drive Set exchangeable set and sledge, I guess it needs to be heavier like yours.
Hey I like your SST to hold up the caliper, I used my rage and spring plates for mine
Jim
'85 Carrera Targa
PCA/POC
Old 07-21-2011, 06:56 PM
abit off center
cgarr's Avatar
The driver turns when you hit it, you will see when you pic one up.
Craig
G2Performance
Old 07-21-2011, 06:57 PM
DRACO A5OG's Avatar
oooh, Thanks PabloX, Cgarr & Dad
So that impact tool actually turns the screw when you hit the tool? That is ingenious!
'85 Carrera Targa
PCA/POC
Old 07-21-2011, 06:58 PM
Oh Haha's Avatar
+1
One of the many tools I have purchased to work on the 911.
Actually, I have used it on a couple of other jobs as well so it's worth having in the toolbox.
Pacific Blue
Wayne
Old 07-21-2011, 06:59 PM
RETIRED
Joe Bob's Avatar
I have a hammer impact. I've found that one whack in tighten mode, then switch to lefty loosey....
2012 ML350 3.0 Turbo Diesel
Old 07-21-2011, 07:02 PM
redridge's Avatar
great tool.... even when the screw is stripped, still worked great.
Old 07-21-2011, 07:03 PM
I don't even try a standards screwdriver on those screws anymore. I just get the impact screwdriver, and if it won't turn with normal force, then I get out the hammer. But the impact screwdriver makes a good driver.
The Harbor Freight one has a sort of motorcycle grip, and it's thick so you can turn it with a lot of force just using your forearms.
Old 07-21-2011, 07:04 PM
rs6er's Avatar
Send a message via AIM to rs6er Send a message via Skype™ to rs6er
+1 The impact driver worked great for me. This is exactly why I bought it.
John
Original owner '81 911SC blackmetallic coupe. Terbatrol, SSI, M+K Gen 4, SC+ cams, A/C delete, console delete, heater backdate, 7 & 8 x 16 Fuchs with polished rims, Turbo tie rods, tensioner update, Rennline engine mount bar, Mainely Custom sump plate, new top-end, corner balance.
Old 07-21-2011, 07:06 PM
DRACO A5OG's Avatar
Salomi Salomi you Wise Young Gentlemen
I learn everyday here, I love it !
'85 Carrera Targa
PCA/POC
Old 07-21-2011, 07:07 PM
Exactly. The one I have can be turned to operate in either direction.
2016 VW Golf R
2021 Kia Telluride
2020 BMW R1250RS
Old 07-21-2011, 07:19 PM
DRACO A5OG's Avatar
Originally Posted by PabloX View Post
One of these:
Update: Got the HB Tool. Worked like a Charm on the first try.
Caveat: no instructions so make sure it is torquing in the correct direction.
Thank Fellas!
'85 Carrera Targa
PCA/POC
Old 07-30-2011, 06:55 PM
RETIRED
Joe Bob's Avatar
ummmmm look at the arrows of the tool in yer pic.....
Old 07-30-2011, 06:58 PM
