Where does the brown/ red wire go?
Can anyone tell me where the brown and red wire goes from the fuel pump relays in a 88 930?
Fuel pump relays are not being triggered. Help, anyone? Kelly |
there is a brown-red in the engine bay. it connects to a sensor on the back of the CIS i believe.
Thanks, Is that in a 88 930?
I think the 930 uses CIS correct? There is a place to connect the brown /red on CIS cars. Perhaps the experts will weigh in. When I took out my CIS i definitely disconnected a brown /red.
Thanks for your reply, I would really like to find out where to start with trouble shooting this issue. Come on pelican experts where are you guys when I need you most?
Help? Thanks, Kelly |
It's the ground wire for the relais and goes to the boost switch/ meter plate switch and therefore pumps stop running when boost too high or engine stopped (no vacuum) SmileWavy
| All times are GMT -8. The time now is 12:40 AM. |
