LinkBack Thread Tools Rating: Thread Rating: 22 votes, 4.77 average.
Wow.
Can you help me with mine project
I look forward to more details
Michael
Old 08-07-2011, 08:08 PM
Arlo911's Avatar
Are you planning a small production run of any of these awesome parts you keep posting?
Early S member #1969
Old 08-07-2011, 11:11 PM
great question !
Old 08-08-2011, 04:23 AM
Cornpanzer's Avatar
sub'd
Check out my blog for Parts & Cars For Sale - http://renn-spot.blogspot.com/
1970 911S,
10 sec 67 Beetle (300 rear wheel HP)
RGruppe#252
Old 08-08-2011, 04:33 AM
That light weight dual master cylinder set up is so neat
Michael
Old 08-08-2011, 04:42 AM
simonozrs's Avatar
Subscribed! This is high-end work, thank you for sharing it.
2012 Porsche Cayenne S V8
1974 Porsche 911 IROC Tarmac Rally
1978 Porsche 911 Gravel Rally
1978 Porsche RSR Speciale under construction
Old 08-08-2011, 06:41 AM
Fantastisch!
Cheers, John
1982 SC Targa
1970 T 2.4E/915(project)
Old 08-08-2011, 08:11 AM
Midwest R Gruppe
t6dpilot's Avatar
Originally Posted by Cornpanzer View Post
sub'd
No doubt dude, me too... Nice build.
Scott
69E Coupe 2.2S LtWt
70 914-6 GT
Great Craftsmanship !!!
Old 08-08-2011, 08:49 AM
Subscribed!
this is a awesome build... follow up if your going to make any parts for sale... include me!
James
1973 911T - 3.6VRAM, G50/5Speed
1978 to 1973 Turbo with RSR Look, 3.8Ltr TT, G50/6Speed
2010 GT3RS
Old 08-08-2011, 02:42 PM
Very nice work. Subscribed.
Old 08-21-2011, 01:19 PM
super9064's Avatar
I'm impressed, this will turn out nice
Old 08-21-2011, 01:45 PM
leichtbauer
leichtbauer's Avatar
I need your assistance. Someone has pictures or a design of that inside 72 oil tanks. I would like to build this tank in aluminum.
Mine setup is oil tank, filter of 72 - 911, front-oil-cooler of 91-962.
Old 08-25-2011, 11:29 AM
Bland
RWebb's Avatar
some pics I've gleaned - just promise to post pics of your progress...
have you considered fabbing the '72 tank out of carbon fiber instead of Al?
Old 08-25-2011, 03:44 PM
Bland
RWebb's Avatar
BTW - are you looking for data on component wts.?
Old 08-25-2011, 03:47 PM
Bland
RWebb's Avatar
Originally Posted by pksystems View Post
What is that top item? window regulator? How did you make it lighter?
I dunno if losing 2lbs from that low of the front (crossmember) will make a diff.... but I guess if you're trying to shave all possible weight.
I am also curious about the top question.
re the crossmember - the Al piece is also stiffer & his wt.s are in kg
also curious how much wt. you saved on the dual m/c pedal assembly
and... if you want some (high end) inspiration, you might go to the 964 forum on Rennlist and look at the America GS thread (pinned to the top)
Old 08-25-2011, 03:48 PM
leichtbauer
RWebb -> wt. original SCRS Pedalbox is 4.5kg. my pedalbox is 3.6kg
to all -> am looking for pictures of an open oil tank 72. I want to see how the pipes, screens and plates are mounted inside the tank
Old 08-25-2011, 10:53 PM
I havent been able to find a picture for you, but I will surely post one if I do find one. I see you are building a hot rod, and if you are planning on building an engine that tevs past 8k rpms, I would highly recommend using a high performance aftermarket tank, because the original oil tank cant move oil fast enough and you will ruin a bearing in the engine. But if your going for originality and your not going to revving the thing to the moon, than you should be fine
'80 911 sc
'96 Range Rover
Old 08-25-2011, 11:12 PM
Leichbauer - I am awed by your skills!
It is fantastic to see you going for lightweight solutions all the way through your build! I am looking forward to the rest!
It is great to see the weight of the new parts you replace with the originals. Very, very interesting
Fight the fat! (I guess you recongnize this slogan, from a well known European uncompromising motorcycle racing manufacturer...) I love it myself as a former member of that community
Old 08-25-2011, 11:54 PM
Arlo911's Avatar
Maybe someone can help you on the Early S Registry forums for the pictures or drawings of the inside of the oiltank?
Old 08-26-2011, 09:00 AM
