malpaslane's Avatar
Pedals...?
Hi All, i first asked a question about my clutch pedal sitting to low some time back,but i still haven,t been able to find the problem, my car is a 2.7 1975.
This weekend i was cleaning the interior and looking at the pedals, the brake pedal is more towards the seat than the other two are , could the brake pedal be my problem and not my clutch pedal as i thought, my clutch works fine and the adjustment looks ok and the pedal sits inline with my gas pedal, if the brake pedal is wrong , how do i get it to in line with the other two.
cheers
Rik
RIK 911 2.7 76 summer only
924 gts repilca - sold
924 turbo s2 - sold
924 turbo s2 nightmare car -sold
Old 03-28-2011, 08:45 AM
brads911sc's Avatar
have you rebuilt your cluster recently?
83 SC Targa -- 3.2SS, GT2-108 Dougherty Cams, 9.5:1 JE Pistons, Supertec Studs, PMO ITB's, MS2 EFI, SSI's, Recurved Dizzy, MSD, Backdated Dansk Sport Stainless 2 in 1 out, Elephant Polybronze, Turbo Tie Rods, Bilstein HD's, Hollow 21-27 TBs, Optima Redtop 34R, Griffiths-ZIMS AC, Seine Shifter, Elephant Racing Oil Cooling.
Old 03-28-2011, 09:35 AM
Mo money = mo parts
You didn't provide much information so the best we can do is to guess. It's really a process of elimination. First, you need to have a good clutch cable in the car. Second, the cable needs to be adjusted correctly. Third, the pedal cluster in good working order. And last, the springs need to be able to produce the original spec tension. The clutch pedal has three springs that affect it's movement - two at the transmission and 1 at the pedal cluster. Any one of those could contribute to your problem.
If it were my car, I would probably follow the sequence above to figure out what was going on. The cost could be $0 to a max of $200 for parts. Labor depends on whether or not you do your own work.
Others may have different recommendations.
Greg
86 Coupe (stock - pretty much like Butzi designed it) - gone, but not forgotten
65 Ducati Monza 250 & 66 Monza Junior (project)
"if you are lucky enough to own a Porsche, you are lucky enough"
Old 03-28-2011, 10:02 AM
malpaslane's Avatar
Hi,
i haven,t rebuilt the pedal cluster, but i did fit a new spring at the clutch pedal end about a year ago and a new clutch cable was fitted as well, on my year of car i think there is only one spring, there isn,t any spring at the gearbox end, the clutch adjustment is right and it works fine.
My problem is that i always thought the clutch was lower than the brake pedal and that was what was wrong, now i,m looking at it thinking it could be that the brake pedal could be the problem, as the clutch and gas pedals are inline with each other and the brake pedal is further forward towards me.
thanks for help
Rik
924 turbo s2 - sold
Old 03-29-2011, 12:15 AM
AutoBahned
RWebb's Avatar
MY = 1976?
post a pic
Old 03-29-2011, 12:28 PM
