what ECU to use ? 3.0 with 3.2 EFI
I have a 1978 3.0 that is currently running 40mm Weber carbs. Runs good with good throttle response but I'm thinking EFI might be the way to go. I just purchased from a fellow Pelican a 3.2 intake system. I have everything except the OEM ECU, ECU harness and the barn door air flow meter. So I could get the rest of the OEM parts or I can go aftermarket and that's where my question is. A few years ago I attempted a Megasquirt EFI install and it went poorly and I will not use that again. So what ECU's are out there that you guys recommend ? At this point I don't know if I want injection only or injection/ignition. I do have all the parts from a Ford EDIS laying around. Car is street driver but weekend AX/DE. And finally any experts in Atlanta Ga. area that you would recommend for install/tuning ?
2002 Boxster S . Arctic silver + black top/int. Jake Raby 3.6 SS engine " the beast ". GT3 front bumper, GT3 side skirts and GT3 TEK rear diffuser. 1999 996 C4 coupe black/grey with FSI 3.8 engine . Rear diffuser , front spoiler lip with ducktail spoiler . |
