Front Strut Mount Bolt Stripped
In going over my suspension this weekend I found that one of the bolts which is attached to the passenger side front strut mount is stripped. I'm pretty sure it is both the bolt and the nut (which is attached to the strut mount) that are stripped. However, I'm going to pick up a new bolt from the hardware store today and see if it will thread in. Maybe I'll get lucky and only the bolt is damaged.
If it does turn out that the nut is damaged and I need a new strut mount, my question is: Do I need to take care of this immediately? Or can I still drive the car this way? I recently had the car aligned about a year ago and don't want to have to do it again so soon. (I'm not sure why the shop didn't mention this to me when they did the alignment.) It's the bolt on the outside. ![]() Another option I thought of, is getting a longer bolt and another nut that I can sandwich on top of the nut that is welded to the mount. Would this be an acceptable fix?
Matt. 83 911SC 85.5 944 NA - Sold |
abit off center
The nuts are just tack welded to the plate in fact one of my came off. just put another nut on it for now. Its just kind of hard to get in there that's why they are attached to the plate.
______________________ Craig G2Performance Twinplug, head work, case savers, rockers arms, etc. |
So if that's the case, could I just grind off the nut and replace it?
you could try to run a thread chaser or tap through the nut to see it if is still usable. you can get a cheap tap & die set at harbor freight or just buy the size you need and a tap handle at a part store. i've had good luck before just running a good bolt through the other side of the nut where only 1-2 threads were damaged on the other side (the redneck thread chaser).
1982 911SC, Mocal oil cooler, Bilsteins, Carrera tensioners, backdated heat, factory short shift, Seine gate shift, turbo tie rods, pop off. 2005 Mercedes-Benz C230 kompressor sport 6-speed (daily driver) |
abit off center
Yea but you have to take out the whole plate to get to it I think? then your alignment might change.
New bolt- chase the treads- if it doesn't tighten put another nut on it.
Pete 79 911SC RoW "Tornadoes come out of frikkin nowhere. One minute everything is all sunshine and puppies the next thing you know you've got flying cows".- Stomachmonkey |
I ordered a tap and die set from amazon (just metrics) for about $ 30. The keys were, using a generous amount of thread cutting oil, going slow, and tightening until I felt resistance and then backing off a half turn and the start tightening again. The new bolt threading in and torqued up with no problem. I really had no knowledge of using taps and dies before and didn't think I had any use for a set. You've opened up a new door for me. Thanks guys!
