eubanksae's Avatar
Send a message via AIM to eubanksae
Unhappy My car is dying occasionally, need advice...
All of the sudden, on my way home from work tonight, my engine lost all power, and when I put the clutch in, it stalled. I was able to restart it immediately, but a minute later it did it again. It happened 4 times on the 15 minute drive home.
Any ideas ?? Is it the fuel pump ??
Please, help...
Thanks,
Andy E.
Lakewood Ranch, FL
eubanksae@yahoo.com
Black '78 - 911SC Targa
Old 02-14-2002, 04:03 PM
stormcrow's Avatar
Well, it could be an electrical problem. Check your distributor and rotor along with your coil wires. There could be a problem there.
As far as a fuel problem, you need to have a pressure gauge to check pressures.
Old 02-14-2002, 04:50 PM
Check the low tension wires.
Check all grounds, check coil, get CD unit checked/tested.
Good Luck.
Nick
'85 Carrera
Old 02-14-2002, 04:59 PM
