I'm here to cause trouble
jimbauman's Avatar
Carrera distributor cap wear
I started getting an occasional miss and stumble at the low end - popped the cap and saw this ... rotor was down tight.... is this common?
JB
'86 Carrera Cabriolet '73 911T Sporto (RIP)
'90 Miata LeMons Contender! '71 Datsun 510 (RIP)
'67 Fiat 124 Sedan (RIP) '72 Ford Pinto (RIP)
'62 Plymouth Valiant '60 Ford Galaxy 500 (RIP)
Old 03-27-2011, 09:48 AM
kodioneill's Avatar
I don't know if it's common but I think you found your miss. How's the rotor look?
1974 sahara beige 911 targa
1982 chiffon 911sc
1985 prussian blue metallic carrera
Old 03-27-2011, 10:18 AM
I saw that same thing last summer on someones race car..
Bruce
Old 03-27-2011, 10:53 AM
dshepp806's Avatar
too much, for sure..
Doyle
Recording Engineer, Administrator and Entrepeneur
Designer of Fine Studios, Tube Amplifier Guru
1989 Porsche 911 Carrera Coupe
25th Anniversary Special Edition
Middle Georgia
Old 03-27-2011, 01:00 PM
muck-raker
kidrock's Avatar
not common, but definitely f'ed up. You found your problem.
STONE
'88 Cabriolet, using EP Slick 20w50 partial synthetic Snake Oil...just as Rommel intended.
Deny Everything; Admit Nothing; and Always Make Counter-accusations
Old 03-27-2011, 03:39 PM
Might be good to know if these are the replacement "Bosch" pieces made in Spain, Yugoslavia, or wherever. Isn't the center post a bit "Springy"...and does the spring still work?. Does it look like mechanical or electrical distress up-close?.....forensic minds want to know !!.
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 03-27-2011, 05:03 PM
How many miles on that cap?
Scott Wilburn
1988 911 Carrera 3.4 L
1998 M3
1984 308 QV
Old 03-27-2011, 05:05 PM
jimbauman's Avatar
Not a lot of miles - maybe 12K. I popped in a new one (made in Spain.. not sure about the damaged one) and had a closer look at the old one. The light colored area seems to be where the cap melted as the electricity tried to find a path.
The carbon rod looks like it might have broken off. I'll take a closer look when I can... Anyhow, runs much smoother now... so... new plugs, new cap, can of fuel system cleaner working it's way thru the system... we'll see if I pass smog in the next week or two, or even come close!
JB
Old 03-27-2011, 05:59 PM
John W
About 15k miles is time to change so you were getting close to it.
John
89 3.2 Targa 123k miles
Old 03-27-2011, 08:05 PM
Distributor cap...
I recently ordered a Beru cap from Pelican for my 3.0 SC, and it appeared to be better finished (made in Germany as well) than the last Bosch (made in Spain) unit I bought.
It's also significantly cheaper (for a Carrera) than the Bosch distributor.
Old 03-27-2011, 08:56 PM
I had the same problem on my 73S. After a few hundred miles I heard a ticking noise and thought it was a valve tick or a spark plug wire. Turned out that a piece of the carbon rod broke off and was bouncing around. At first I thought that the rotor or cap was not seated properly. Then after a few miles on a new cap and rotor, which was properly seated , I noticed that the rotor had shown a slight meltdown. I have MSD and installed a VW Beetle rotor(Jeff Higgins way) and no problems yet.
Old 03-28-2011, 04:22 AM
