So I've got my motor out having a great learning experience. I think I'm working on a 911T.(Webers etc. etc.) I notice on the fwd end of the left side cam shaft the sprocket for the injection fuel pump and several studs on top of the case where the injection pump would be mounted. I look at the cars VIN number on the registration -119 22 0626. A 69, E Karmann Coupe. Someone has done body job on it (Carrera look alike).
Did T engines get shipped with the fuel injection sprockets and studs for retrofit, What's a Karmann coupe, How do I tell what I've got,should I care? especially when I'm ordering parts for the motor as a T. BTW there is no chassis plate visible at the front of the car as the location is hidden by the sheet metal filler across the bumper to hood sill. There is a picture of the car on my profile page on this board.
Steve F 69 911 71 911 87 Carrera 2004 RAM 1500 4x4 "Hemi" |
What color is the engine shroud ? Green indicates and E motor. Hope this helps.
2014 911 GT3 1979 930 Turbo 1970 911T 2016 Cayman 2019 Macan |
Friend of Warren
Steve you need to find the engine serial number. Is on a flat surface on the engine just to the right of the fan. The attached link will show your how to decipher the engine number to find out if you have a T or an E. http://www.911t.org/TechSpecs/number_codes.htm Most T bodies were made by Karman, nothing unusual there.
Kurt V No more Porsches, but a revolving number of motorcycles. |
Thanks, I'll look tonight, The engine shroud is green, So I could assume someone converted back to conventional carbs. Cool.
Stay away from my Member
This is a little bizzare.
I haven't checked other sources, but according to the Porsche Classic web page for 1969 ( http://www.us.porsche.com/english/excitement/classic/911/1969.htm ), Karmann didn't build any 911's that year. In fact, I didn't think they built anything but T chassis. [edit - oops, checked again, they did at least build some E coupes as well as T coupes] The green engine shroud of course indicates an E engine though, but it should have MFI. There would be tell-tale signs of MFI on the car, such as the pump belt drive on the cam and the heat hose on the left heat exchanger. The T's had Zeniths IIRC so if it has webers it most certainly sounds like a converted E. Anyways, have fun with it! And if it's an E...please sign up for the 911E Registry www.911eregistry.org Cheers,
Chris C. 1973 914 "R" (914-6) | track toy 2009 911 Turbo 6-speed (997.1TT) | street weapon 2021 Tesla Model 3 Performance | daily driver 2001 F150 Supercrew 4x4 | hauler Last edited by campbellcj; 02-14-2002 at 09:31 PM.. |
Hello
You're VIN 119 22 0626 is for a 69 911E Porsche Coupe. A Karmann Coupe would have a 0 as the fifth number instead of a 2 in the VIN (for an E). Re: the engine serial number look at the second number. 1 for T 2 for E 3 for S Approximate Karmann chassis built for 69 model year. T 343 E 954 S 1492 Should be a 911E converted to Webers. Hope these numbers are accurate and helpful. |
For those who are anal....
According to "Original Porsche 911" my '69T is a Karmann-made coupe. It came with Webers. The 70 & 71 (and maybe the 72 & 73 in ROW?) came with Zeniths. Cam
1975 911S (in bits) 1969 911T (goes, but need fettling) 1973 BMW 2002tii (in bits, now with turbo) |
