i have a 1975 porshe targa it has been setting for 9 years i am trying to get it back running the engine works good but their is no fuel getting to my engine i have replaced the fuel tank i have taken the fuel distributer apart and their is norust in it also i replaced the fuel hoses so what might be the problem
If there is no fuel getting to the engine, check fuel pump operation...
Dustin |
fuses, relay, etc..
Its easier asking dumb questions than fixing dumb mistakes 1974 Porsche 911 Coupe, RSR Project 1976 Porsche 911 Targa, Black 1986 Porsche 911 Carrera, Black 2006 Porsche Cayenne S, Black |
Obsessed
you are going to have to work backwards to find the offending blockage.
-Is fuel getting TO the pump if you unclamp the soft line in front of it in your rear wheel well (easy check) -Is the fuel pump running when key is on (easy to hear) (is it new, does it have a good check valve in it?) -are you getting fuel TO the fuel dist.? You need to narrow down where the lack of fuel delivery is. Is there gas in the tank
'73 Mercedes 450 SL '75 911 Targa (long gone, sniff..) http://1975porschetargarebuild.blogspot.com My Targa Rebuild Blog "Life moves pretty fast, if you don't stop and take a look around once in a while you could miss it!" |
| Tags |
| 1975 porshe targa |
