Porsche Crest 1975 porshe targa
i have a 1975 porshe targa it has been setting for 9 years i am trying to get it back running the engine works good but their is no fuel getting to my engine i have replaced the fuel tank i have taken the fuel distributer apart and their is norust in it also i replaced the fuel hoses so what might be the problem
Old 03-31-2011, 10:36 AM
redstrosekNic's Avatar
If there is no fuel getting to the engine, check fuel pump operation...
Dustin
Old 03-31-2011, 12:13 PM
fuses, relay, etc..
Its easier asking dumb questions than fixing dumb mistakes
1974 Porsche 911 Coupe, RSR Project
1976 Porsche 911 Targa, Black
1986 Porsche 911 Carrera, Black
2006 Porsche Cayenne S, Black
Old 03-31-2011, 12:34 PM
Obsessed
sobamaflyer's Avatar
you are going to have to work backwards to find the offending blockage.
-Is fuel getting TO the pump if you unclamp the soft line in front of it in your rear wheel well (easy check)
-Is the fuel pump running when key is on (easy to hear) (is it new, does it have a good check valve in it?)
-are you getting fuel TO the fuel dist.?
You need to narrow down where the lack of fuel delivery is.
Is there gas in the tank
'73 Mercedes 450 SL
'75 911 Targa (long gone, sniff..)
http://1975porschetargarebuild.blogspot.com My Targa Rebuild Blog
"Life moves pretty fast, if you don't stop and take a look around once in a while you could miss it!"
Old 03-31-2011, 12:42 PM
Tags
1975 porshe targa
