-   -   Shifting problems... (http://forums.pelicanparts.com/porsche-911-technical-forum/600373-shifting-problems.html)
Gary (guest) 03-31-2011 10:51 PM
Shifting can be hard going into 1st and 3rd. Sometime I have to double clutch first. Is this a linkage problem?
This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: 911 Shifting Improvements
Wayne 962 03-31-2011 10:51 PM
I typically like to start with the things that are easiest to fix. In this case, yes, that would be shift linkage. Go through the linkage and replace all of the bushings that may be worn, including the coupler underneath the car in front of the rear seats. Then, you can accurately evaluate the shifting, and focus on the transmission if the problem still persists.
- Wayne
DRACO A5OG 03-31-2011 10:54 PM
It can be many things but first we need to what year your 911 is.
Register and use the search function to find others with similar issues.
Drisump 04-01-2011 07:37 AM
As what was said in earlier posts, a 915 tranny is something to learn. She doesn't like to be rushed even when she's in perfect health, the clutch is good and all linkages are good. Taking it to a typical dealer for a PPI isn't the best choice, very few of their staff have any knowledge whatsoever about the older models. A 915 with Swepco (a typical tranny oil in a 915) takes some heat( especially in cold weather) to get to optimum performance (ie. it is even slower to use smoothly when cold). Take it to a very experienced independent for a real appraisal.....at least on this issue. Good luck
r_towle 05-06-2011 07:31 AM
Shift linkage first.
Replace gear oil with DINO oil (Kendal makes a nice product)
Do not use synthetic oil in a 915 tranny.
Use synthetic in a G50.
The syncro bands in the 901/914/915 tranny need regular dino oil only.
Rich
CCM911 05-06-2011 08:58 AM
- Wayne
Wayne is totally correct in his response. I did what he is suggesting. In fact Pelican even sells a kit. No Brainer. Between the new bushings and adjusting my coupler, my car now shifts like brand new. Think about it, these cars are now close to 30 years old, and those old plastic bushings have either shrunk, broke, or are hard as rock at this point.
