Huey581's Avatar
Door Check Strap
Does anyone have a secret method of removing the pin that
holds the door check strap on? I have hamered that pin till I can't
hammer no more? It is the original strap!
Huey581
86' 911 Cab
Old 02-16-2002, 12:43 PM
MBAtarga's Avatar
Did you remove the circlip from the underside before hitting it
from the bottom?
Mark
'83 SC Targa - since 5/5/2001
Old 02-16-2002, 02:40 PM
Huey581's Avatar
Finally got it after a good soak and a bigger hammer. The old style pin has no circlip. It pounds down from the top. After installing the new one, it now "clicks" because the new pin is
too thin! I just can't win with this thing. I may use the old pin.
Huey581
86' 911 Cab
Old 02-16-2002, 04:51 PM
