Go Back   Pelican Parts Technical BBS > 1- Porsche Technical Forums > Porsche 911 Technical Forum
Help with steering wheel removal '88 911
Pelicans,
I am trying to remove factory steering wheel. Horn pad off. Breaker bar, socket, pentrating fluid around nut. Still no budge. Tips? Seems like would be pretty straight forward. What am I missing or am I just weak?
Old 04-03-2011, 08:37 AM
pete3799's Avatar
Probably just weak.
Don't use the steering wheel lock to hold it or you'll break it.
If no air gun, drive it somewhere and have them zip it off then snug it back up for the drive home.
Pete
79 911SC RoW
Old 04-03-2011, 08:52 AM
Joe Bob's Avatar
^^^^ good suggestion....or two people and a long cheater bar. One guy holds the wheel.
See me for graphics. www.nbdgraphics.com 83 cab, backdated with 3.6 I want a Porsche fix until I die. 2012 Mercedes ML350, 1980 Suzuki GS 1000S
Old 04-03-2011, 08:54 AM
ivangene's Avatar
+1 for above suggestions
Ed M
86' Coupe
Old 04-03-2011, 09:19 AM
aualexa2's Avatar
If you don't have someone to help you, you can put an anti-theft bar (the club) on the wheel to use to stabilize the wheel while trying to break the nut. However you chose to do it, just be careful not to slip and smash your windshield!
Alex
‘73 914 1.7 Phoenix Red
'87 911 Blk/blk sunroof coupe
'16 Cayman GT4 GT silver
Gone: '13 991S Dbm/ag non-sunroof coupe
Old 04-03-2011, 09:33 AM
NeunElf3.2's Avatar
Elecrtric impact "drill/driver" ...did the trrick on mine.
Old 04-03-2011, 10:09 AM
I had my son hold the wheel while I turned the wrench. It took some force but it came loose.
1985 Triple Black Cabriolet-ROW**Sold**
2008 Cayman S Guards Red/Black
2007 Audi A4 2.0T Red/Black
Old 04-03-2011, 11:39 AM
Air or electric impact wrench is what you need with an impact socket.
73 Carrera RS spec 2.7 MFI
03 Saab 95 Aero
01 Saab 95 Aero
90 Chevy PU Prerunner....1995
RGruppe #79
Old 04-03-2011, 02:05 PM
jdbunda's Avatar
I had this problem with a BMW a few years back. I struggled - finally took it to someone with an air impact wrench - like buttah.
Old 04-03-2011, 02:22 PM
No Radio Required
Let the fluid soak a bit.
You should be able to do it with a breaker bar, as long as it is at least a 24" bar.
Ken
'84 3.2 Targa
"What do you mean NEXT project?" - my wife
Old 04-03-2011, 03:06 PM
76 911S Targa
This is a no brainer. Impact wrench! The steering wheel nut just pops off with an impact wrench. Harbor Freight has a dandy one for $40. A metric impact socket set can also be had from the same vendor for cheap. You will use this electric impact wrench over and over for all kinds of applications. It makes changing tires a breeze too. Forget the breaker bar!
Old 04-03-2011, 03:13 PM
Thanks to all....
Thanks for everyone's input. Impact driver was the ticket. Very quick and easy. New wheel looks fantastic! Thanks again.
Old 04-04-2011, 05:41 AM
KTL KTL is offline
Schleprock
KTL's Avatar
Send a message via Yahoo to KTL
Curious.......... what'd you tighten the nut to when you reinstalled it?
Reason I ask is because I think a lot of people believe you have to gorilla tighten it because the nut/threads are so big. Not so. The torque spec in the Porsche spec book says 50 Nm = ~ 37 ft-lbs
Kevin L
'79 911SC widebody conversion
'86 Carrera
Past: '87 Carrera "The Unicorn"
Old 04-04-2011, 08:03 AM
PCA7GGR's Avatar
If you use a breaker bar, make sure that you are applying force down away from the windshield. This will help avoid a bigger, more expensive problem - ;>)
Sergio
PCA - 35yrs / Ex-RGruppe #197
'04 GT3 Halloween/SF Giants car
'11 E550 Coupe (Königstiger)
Old 04-04-2011, 08:07 AM
Copyright 2018 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
