-   -   72-no turn signals (http://forums.pelicanparts.com/porsche-911-technical-forum/600903-72-no-turn-signals.html)
inaminit 04-03-2011 02:13 PM
72-no turn signals
Hello- I am trying to troubleshoot the turn signals. Neither side responds to the switch, or to the emergency flasher switch. The current flasher is an aftermarket unit that has 3 prongs-not 4 like the replacement. No visible corrosion on the switch. The signals quit all at once, which makes me suspect the flasher. Any ideas? Where to start? Thanks
kidrock 04-03-2011 05:22 PM
fuse?
911t Fanatic 04-03-2011 05:27 PM
most like the flasher if not a fuse. But if it is a fuse i would want to know why it went.
fintstone 04-04-2011 09:38 PM
flasher
inaminit 04-05-2011 06:20 AM
Thanks for the answers. There are several good posts on Rennlist on this subject. The 71 and the74 current flow diagrams help too. I think that I will start by replacing the blinker relay, and thefollow voltage from there.
Dejathoris 04-06-2011 03:14 PM
I also have a '72. Two weeks ago the high beams would come on sometimes and to keep on only the low beams I would have to hold the turn signal stalk slightly towards me. The other day the turn signals just quit working, as well as the flasher. To fix the high beam issue, I read here on Pelican about either changing the switch or bending the contacts so they are not as close, but I think this is unrelated to the signals not working. My fuses are fine. When I turn on either the left or right turn signal, the correct light bulbs (front and back) turn on, but none intermittently flash. When I turn on the flasher, I hear the tick tick, tick tick of the flasher inside the car, but no light bulbs turn on or flash. I pulled the steering wheel and found a brown with white stripe wire going from the combo turn signal/headlight switch going behind the dash but not connected to anything. I could not find a matching wire it should connect to. Can anyone point out the wire this should be connected to? I also pulled the flasher switch and found all wires were solidly connected to it (I did not trace it to each of their ultimate connections). I could not make heads or tails of the electrical diagram in the manual I have since not in color and poorly illustrated. So, sorry I can't give you the answer, only the symptoms. Here's hoping you solve the riddle.
