ohm resistance in 14 pin connector
does anyone have a list of the ohm resistance that I could use to track down a short to ground problem I am having?
I need to check from both the male and female ends at the 14 pin connector Thanks in advance Sorry the car is an 82 SC
1982 SC |
porsher
not sure i understand your question exactly....
however a short to ground will give you between 0 and .4 ohms. the reading may jump around a little if things are not completely clean. sorry if that was no help :-)
86 911 Race Car, with a few 993 bits in the boiler room 79 928 Race Car 88 928 Becoming a Race Car |
If your meter has a beeper function to show continuity, just hold one lead to ground and test for continuity across the pins.
The Uncertainty Principle. It proves we can't ever really know...what's going on. So it shouldn't bother you. Not being able to figure anything out. Although you will be responsible for this on the mid-term. -Larry Gopnik |
I have disconnected the batteries ground and apply the volt meter to the pins in the 14 pin connector and ground.
My understanding is that if there is a short to the ground I will get a reading if there is no short to ground I will get no readings
1982 SC |
Use continuity or test light..........
Steve, Set the multi-tester @ continuity test (with beeper) or use a simple test lite/lamp. I went over your data for pin #2 (male) with 86 ohms reading (???) This is a ground wire and not in use. Plus the other terminals that are connected to the dash instruments would show resistance (ohms) during the test. What made you think that there is 'unwanted ground' in one of the circuits? Are you blowing out fuses? How come you got ZERO reading for terminal #10? The WUR and AAR have a combined resistance of 50 plus Ohms. Thanks. Tony |
Here's a link to long story
help with freakish non start problem I'm at my wits and skills end. Electronics is not my strong suit
1982 SC |
Short story for my inquiry is that if I turn the key to start the car I am getting 12 volts at the yellow terminal 30 but the starter will not turn.
I ran a direct fused line with a momentary switch from the battery to the terminal 30 and the starter turns the car right over. If I pig tail the yellow wire to my direct line and push the momentary switch the starter does not engage and the fuse in my direct line blows. Therefore I figure the electricity is traveling up the yellow line to a short somewhere. If I start the car with the yellow wire disconnected it starts fine but then after about 30 secs runs like crap Thanks
1982 SC |
Need some clarification........
Please confirm that this is just a typo. Terminal #30 from your above post is misleading!!!! Terminal #30 has the RED cable wire from alternator, and the BLACK cable wire from the battery at this terminal. Terminal #50 has the YELLOW wire from ignition switch via 14-1 connector. Terminal #30 will always have 12 volts as long as a fully charged battery is connected. It has nothing to do whether you turn the ignition switch ON or OFF!!!! Secondly, I know why the fuse in your direct line blew after connecting it to the yellow wire. But let's hold it until we clear the matter. It will only add to your confusion. First, let's establish that you are doing the test on the correct terminal (s)!!!!!! Keep us posted. Tony |
Now I'm getting confused too.........
Steve,
There must be some logical explanation to this and you're the only one who could help clear this matter. Quote:
There is only one (1) connection you need from the 14 pin connector to activate the starter and that's 14-1 with the yellow wire. I re-read your original post and these guys namely: Pete3799 Walter_Middie T77911S (TY) Ipacketeer 1990C4S Had given you some directions to check your starting problem and they make sense to me. If you are interested in finding the 'ground fault' just use a continuity tester or a test light and forget the resistance (ohms). The information/data you have provided are not helping you at all. Tony |
Sorry guys. I connected it to terminal #50.
The fuse was rated for 10 amps and does NOT blow when I start the car with just the direct line, but does blow when I pigtail the yellow wire at terminal 50. That is why I figure there must be a short somewhere because the yellow wire at terminal 50 will not provide enough amps to engage the starter and blows the fuse when pigtailed to the direct line How do I run a continuity tester?
1982 SC |
Multi-tester.......
Take a good look at your multi-tester and look for the symbol on the face of the instrument. Or read the manual instruction if you have one. Or post a picture of the tester and people would direct you to the proper setting. I got a Fluke and another 2 multi-testers and they are set differently from each other. When you successfully started the engine with the direct line (with in-line fuse), was the yellow wire still connected @50? Or disconnected? I'm not exactly clear with the 'pig-tail connection' but could you elaborate on it? Showing your set-up during tests with digital pictures would be much appreciated. I'm still having a problem understanding why you're having such a difficult time locating the fault. I doubt if the yellow wire is 'shorted' but I could be wrong. Don't give up, it is something obvious that you haven't discovered yet. Tony |
Thanks Tony and thanks for the PM. I may take you up on the offer this evening if I can't get this done today.
When I try with just the yellow wire attached to terminal 50-no starter engagement If I try with just the direct line at terminal 50- starter engages and car starts If I try with the yellow wire and the direct line both attached to terminal 50- no starter engagement and the fuse in the direct line blows
1982 SC |
Here's my volt meter
1982 SC |
Continuity test.......
Steve,
Place the selector to about 5 O'clock position where the arrow + & sound symbols are located. Plug the red wire @ RED and the black wire @COM. Keep us posted. Tony |
Then do what?
Should I place the tips starting at the ignition switch and the starter? What would I be looking for and what should the meter do?
1982 SC |
Steve,
After you have set the tester for the continuity test (@arrow+Sound symbols), plug the probe wires RED & BLACK. Connect or make the tips (probes) come in contact and see if you could hear the beep sound. The beep sound is an alert that there is continuity on the line. Tony |
Yes when I touch the tips the meter beeps. Now what should I test?
1982 SC |
Thanks Tony.
Maybe you can help me out. I disconnected the battery. I put the continuity on terminal 50 and a good ground on the ignition switch and got no sound , so that s good with no short to ground. I disconnected the yellow wire at the starter. I checked terminal 30 (both) on the ignition switch and got a sound, which I assume means the is a ground short somewhere. I unplugged the harness at the 14 pin connector. I retested terminal 30(both) at the ignition switch and still got a tone. Does that mean I have a short to ground somewhere between the ignition switch and the 14 pin connector? To recap. I have unplugged the ignition switch and unplugged the 14 pin connector. I am getting a continuity sound at the 30 terminals on the ignition switch Thanks
1982 SC |
Sorry
I got my terminals confused. If I am getting continuity at terminals 30 at the ignition switch with the battery disconnected then I must have a ground fault or short to ground between the two red wires and the switch, right!?
1982 SC |
