Removing transmission ground strap?
Does anyone have any secrets for removing the ground strap from a 915 trans? I am chasing a ground problem and I need to remove the ground strap from the transmission and the only way I see getting to it is to remove the transmission mount. There has to be a better way?!
1982 SC |
1/4 inch drive long extension and universal joint worked for me.
Go in above the trans. mount bar.
Pete 79 911SC RoW "Tornadoes come out of frikkin nowhere. One minute everything is all sunshine and puppies the next thing you know you've got flying cows".- Stomachmonkey |
Thanks. What size is the nut?
1982 SC |
IIRC it's 13MM.
Edit: Might be12MM
Hey Steve:
What's wrong with your car? What you are doing seems odd to an electrical engineer. Remember me? I have your brother's old cab..... |
