Scout012's Avatar
Firewall insulation deteriorating
I am working on the VAC,CIS and Injectors on my 1979 930 and wanted to replace/fix the dry rot insulation behind the engine while exposed. Any ideas on what to use?
I also need to remove old foam and glue but don't want to damage any other rubber or plastic parts. there is very little original material left in place.
I plan to scrape as much off as possible then need to apply an adhesive remover to the old glue? Also does HOST sell a replacement? couldn't find one.
Old 04-06-2011, 01:00 PM
76 911S Targa
This one has been highly recommended in other posts because it is semi rigid and can be simply clipped in place without glue.
PEL-APBZ-ESPULT-B
Ultimate Engine Sound Pad, Dense Foam with Skin Bonded to Reinforced Foil Backed Felt, 911 (1969-89) [More Info]
$129.00
Old 04-06-2011, 01:09 PM
Scout012's Avatar
Love the fast responses you get on Pelican.
Thanks, that looks like it will work.
Old 04-06-2011, 01:13 PM
Senior Advisor
James Brown's Avatar
I like the light weight one, it's black foam. Spray on some 3M and it sticks fine.
08 Cayenne Turbo
Old 04-06-2011, 01:15 PM
tobluforu's Avatar
Just installed this last weekend with engine out, you can do it with it in but it will be a tad bit of a hassle.
Old 04-06-2011, 01:22 PM
