Hi guys,
How many oil breather ports does the 3.2 Carrera motor have? I know there's an oil breather port on the neck of the oil tank, but are there any others? I want to install an oil catch can to catch the oil vented from the engine, instead of re-routing it back into the intake / engine. This is for a turbocharged 3.2 motor. I don't want to vent via a small K&N filter into the engine bay. Done that, and the oil mist has made a real mess and the smell in the engine bay is real bad ![]() Advice greatly appreciated. Last edited by 911TT33; 04-08-2011 at 11:54 PM.. |
Can't help you with the number count.....but be careful on doing a good design for this....
...probably best to capture the mist in a liquid-collecting container, let's say tube is connected as a top/side entry to this container....*itself* being vented ( on top, natch) with a mist filter to atmosphere on top....and a drain valve on the bottom.... ...but of course....you probably knew that....
Wil Ferch 85 Carrera ( gone, but not forgotten ) |
