1974 911 w/ 83 SC engine
Oil on the air intake flap on an 83 SC?
My car was having a hot-start issue yesterday, and while investigating the problem I found the air-intake flap inside my CIS airbox had oil resting inside the "valley" of the bent arm that lifts the flapper. It was enough oil to cover the tip of my finger. There was no oil or film of any kind coating the airbox, only pooled inside the arm. It was definitely motor oil. I took pictures but I'm at work and can't post them. What might have caused this, over filling the oil during the last change? And is this a cause for concern?
Old 04-07-2011, 09:13 AM
RETIRED
Joe Bob's Avatar
High oil level in the tank and/or a steep driveway. Oil can get sucked into the intake.
2012 ML350 3.0 Turbo Diesel
Old 04-07-2011, 09:15 AM
Typically overfilling.... 1.) if to the max mark....try just shy of the mid mark and 2.) not following the drill *precisely* as to how to measure:
- car on level surface
- rpm in the 800-900 range ( definately not 1100 rpm, for example)
- up to operating temp... approx 190 degF.... typ. 8 o'clock+ , on the temp gauge.
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 04-09-2011, 10:18 AM
abit off center
cgarr's Avatar
A lot of blow by (bad rings) would also cause this.
______________________
Craig
G2Performance
Old 04-09-2011, 10:25 AM
Send a message via AIM to MrNvgtr
That's part of the air lubrication system. Vaccuum fed in from the oil tank.
Michael
'91 Porsche 964
Old 04-09-2011, 10:38 AM
Hendog's Avatar
Oil in my intake manifold: Carrera (pics)
Similar to the other thread but different. I don't have oil in my air intake, but further down the line I seem to have oil entering at the intake boot. There's a hose connecting from the oil filler throat to the intake boot. This is where I suspect the oil is coming from. I found oil pooled at the bottom of my manifolds. What is this hose for?
BTW, I don't overfill my oil.
Sorry. I meant to start a new thread and ended up adding to this one. Didn't mean to hijack.
Henri
Owned for 21 years: '87 Carrera coupe Venetian blue
Old 04-09-2011, 11:56 AM
