What gaskets/o-rings do I need when rebuilding engine?
What are the gasket names, or which gaskets come with engine rebuild kit?
Contact Don at
http://www.ebsracing.com/ebsnewpage1.htm EBS can supply all the parts you need, including the special Viton O-rings. Ken |
It depends on the engine. It's a long list. I'll start it, I'll forget half of them I'm sure:
1. Oil pump o-rings 2. Case through-bolt o-rings 3. rear main oil seal 4. oil thermostat o-ring 5. breather gasket 6. cylinder base gaskets (copper) 7. barrel compression gaskets (head/barrel gasket) 8. oil cooler o-rings 9. oil-return tube o-rings 10. sump plate gaskets 11. chain box to crankcase gaskets 12. intermediate shaft cover plate gasket 13. crankshaft oil seal, pulley end 14. camshaft to chain box o-ring and gasket 15. chainbox cover gaskets 16. intake/head gaskets 17. carb/injection to intake gaskets 18. injector 0-rings or seals 19. lots of aluminum washers (cam oil lines, oil drain plugs, pressure by-pass valves etc.) 20. valve cover gaskets 21. valve seals That's just a few of them. There's more. Most everything you need is in the gasket set. Pelican sells the sets too. |
| All times are GMT -8. The time now is 07:50 AM. |
