Help: 911 2.2 (1970) fuel pump
Hello everybody, sorry for my english.
I have a problem to switch on my 911. Turned the key and the fuel pump does not start, any sound any move! The starter works fine but the battery is bit weak. Fuse boxes checked and seen to be ok. Thanks in advance for your Help. Regards from italy. GG |
Jump 12 volts to the pump and see if it turns for pressure. Carbs, you only need 3# pressure to the float bowls.
Bruce |
