80 911 SC, Orem, Ut
RSWiser's Avatar
Cleaning up to identify leaks. What is this.
I spent an hour today scrapeing the heavy crusty oily grime off the bottom of my engine and the oil tank.
Trying to clean it up some so I can identify the leaks.
I came across this plug or screw. It is located just aft of the Oil Cooler. What is it?
Rob
1980 911 SC
Old 04-16-2011, 11:49 AM
Oil pressure relief, there is another one on the other side too, harder to get too though.
Bruce
Old 04-16-2011, 11:56 AM
80 911 SC, Orem, Ut
RSWiser's Avatar
Thanks for the quick answer. What is the purpose and should I be doing anything maintenance wise with these?
Rob
1980 911 SC
Old 04-16-2011, 12:17 PM
Unless you have oil pressure problems, just leave things alone. If you create too much pressure in the system this relieves the pressure.
Bruce
Old 04-16-2011, 12:52 PM
Don't mix it up with drain ports----> Stupid Oil Plug Question
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 04-16-2011, 01:31 PM
