Sunroof stoped working
I have an 86 Carrera, last night I hit the sunroof switch and the motor ran but the roof did not move. Worked fine 2 days ago. Where should I start to trouble shoot?
Thanks, BernieP |
Sounds like the cable might have disconnected.
Kipp 1987 Black 911 3.2 Carrera Coupe 1999 Green Mazda MX5 (SOLD) |
Here is a great thread on sunroof repair. Talks about checking the seals and cables.
Sunroof cable repair and new seals 87 911 It helped me out a lot when I was replacing my seals.
Don't mess with cables first....shaft first
I think it is the flexible shaft.
Don't mess with cables yet. Mine did the same thing and luckily I was at TRE at the time. Dave unzipped the headliner pocket near the motor and reached in. The is a flexi drive shaft from the motor to the gearbox. It has a fitting on both end and the middle is sort of a piece of heavy flexible tubing. They break and the motor runs, but nothing gets to the gearbox. Dave gave me a piece of hose to fix mine. I did fix it with that hose and used it as a spare. I ordered a new one from Stoddard part # 901-564-615-06 $23.40 last time I looked out host did not stock them.
RGruppe #79 '73 Carrera RS spec 2.7 MFI 00 Saab 95 Aero wagon stick 01 Saab 95 Aero wagon auto 03 Boxster 90 Chevy PU Prerunner....1990 |
Good idea. The flexible shaft would be much easier to check then the cables.
