Dash - repair, or replace?
So, I have a new-to-me '85, with some cosmetic issues. One that particularly bugs me is the dash (or dash cap, not sure of the correct name). Evidently this car was allowed to sit in the sun, which caused the vinyl to pull off of the dash just below the windshield on the drivers side. The PO tried to halt the damage by stapling the vinyl, but in short, it just looks like crap.
I have a chance to purchase a used dash - described as very good condition - at an asking price of $400. Question - should I purchase the used dash, or is there a way to repair my existing dash? I'm on a bit of a budget... |
Post a pic.
72 911 Although it is done at the moment, it will never be finished. |
Dash Reoair
I vote replace. many good used dashes available, particuarly in Black. $400 is a decent price if in good condition. Your dash may also be warped beyond repair, if this is the case you will have to replace anyway. If you have a colored dash may have to recover, if dash itself is in good condition, not too many colored dashes I seen out there. Mine was blue leather, so my only real option was to have recovered. Google Classic9 Leatherworks........they do phenominal work on Porsche dashes.
1984 911 Coupe 2007 Z4 M Coupe 2008 Cayman S 2004 M3-Alpine White(sold) 2002 M Roadster (sold) |
Have had this dilemma too. Classic9 will probably charge only slightly more than that anyway, and it will be perfect.
Jon '85 930 |
Black and Blue
400 for a used one or have it repaired at Classic 9...sounds like a no brainer. have it repaired.
Kemo 1978 911 SC Non-Sunroof Coupe, two tone Primer Black and SWEPCO Blue, Currently serving as a Track Whore 1981 911 SC Sunroof Coupe, Pacific Blue Project, Future Daily Driver |
Either one is a good price, $400 recovered in leather sounds too good. Last place it checked they wanted $700.
80 911 SC, Orem, Ut
I think my dash is original and it is Blue. So can I assume it is leather? I would like dye it black.
Does the dash come out easily for should I dye it in place?
Rob 1980 911 SC |
Not easy to remove. Need to remove the front windshield to get to the retaining screws.
I would assume if it's warped it's likely leather. What steering wheel is that in the photo above? A Momo?
1986 Targa 1968 MGB (2) |
Taking it apart is easy
If you squint, it says "Prototipo"on it. Momo.
Jerome PLEASE CHECK MY QUIZZICAL BLOG: www.ponderingporsches.blogspot.com |
If you're thinking cheap, then the plastic topper is a good solution. If they are painted up right with a matching "SEM" paint and installed correctly they don't look too bad. I ran one for a couple of years until I installed a re-covered leather dash. I waited to install the new leather dash until I needed to R&R the windshield. Removing and replacing the dash isn't too bad...
Mitch Leland "03" 996 C2S-LS3 V8-480 HP "84" 911 Turbo Look-Sold w/ found memories |
