-   -   How do I tell if my SC is a Euro or ROW? (http://forums.pelicanparts.com/porsche-911-technical-forum/603078-how-do-i-tell-if-my-sc-euro-row.html)
ghamilton 04-15-2011 09:39 AM
Bought my 82 SC last fall. Have all the orig records from factory pickup in Stuttgart.
Owner kept in Germany-Brussels for about 4 years and then imported it to CA. It has the special emissions sticker on the door sill.
Car has been de-smogged, no cat since SC and MA are exempt.
So what differenciates the two models and how do I determine what I have?
pete3799 04-15-2011 09:57 AM
Serial number will tell you.
cbush 04-15-2011 10:00 AM
Does it wear black and have an affinity for Art history? :)
deathpunk dan 04-15-2011 10:03 AM
the vin will tell you. IIRC RoW models have WPOZZZ in the vin.
Skinny rear bumper pads.
equality72521 04-15-2011 10:03 AM
Vin
Va_Powerman 04-15-2011 10:24 AM
and I believe COO indicates Germany, C23 Belgium.
pete3799 04-15-2011 10:34 AM
Check it here
Simon's Porsche 911 SC Site
Drisump 04-15-2011 10:39 AM
Good one!
Oh Haha 04-15-2011 05:52 PM
Correct.
sundevil64 04-15-2011 05:59 PM
My RoW has the big bumper pads.
Another tip is the inside of the light (stop and signal) are painted white versus silver. Obviously, the VIN will be the key indicator.
nesslar 04-15-2011 06:00 PM
I didn't know there was a diff. between "Euro" and "ROW"; aren't they the same aminal? ...as opposed to USA....just askin'.................
Ramathorn 04-15-2011 06:05 PM
Originally Posted by pete3799 (Post 5965463)
Agreed. Most of the little visual things can just be bought and swapped i.e. rear bumper pads, front side indicators, front bumper indicator blanks, ride height, ect.
Oh Haha 04-15-2011 06:05 PM
Typically, they were tagged as US/Canada, Japan, and RestOftheWorld. I think the term 'Euro" was coined by enthusiasts at some point.
The serial # is the only definitive way to know.
Canada Kev 04-15-2011 07:41 PM
There are differences between some of the RoW cars from different markets. Italy was different than Germany which was different from Finland, etc. Usually it's small little things like reflectors, rear fog lights, and stuff like that. For example, mine has the G50/02 transmission (Swiss market) which has different ratios than the G50/00 that most RoW cars have.
RoW would include places like South Africa and others, while Euro is, well, Europe. They have become synonymous, though, in most people's minds.
Another thing is that RoW cars in my experience don't have the VIN plate mounted to the dash or A-pillar. Look in the frunk on the passenger side (may be different in RHD cars) for the data plate. WPOZZZ as the first six digits of the VIN = ROW.
Drisump 04-15-2011 07:56 PM
The Aussie cars were also detuned like the US,Canadian,Japanese were. So the term "Euro" simply describes the fully tuned variety.....even if it was originally spec'd for Dubai. I believe all non-USA/Canadian cars started the serial # with WPOZZZ, even the Japanese and Aussie spec. Cheers
rootmatt 04-16-2011 12:59 AM
Not so or at least not for all years. My '82 SC ROW was Aussie delivered with the full 204HP motor. Don't know about others. :confused:
Matt
Drisump 04-16-2011 06:31 AM
Matt
Sorry sir, I have read that the OZ variation of the 3.2 (not the SC) was the same state of tune as in the US.... Japan and Canada. I guess Australian emission standards were tightened up to match the others after the SC. Like Syzygy says, as part of the serial #, Porsche has placed a number to describe the country which market that the car was spec'd. Cheers
Wil Ferch 04-16-2011 10:47 AM
Jeepers this shouldn't be so hard.....
First of all, someone here ( Nesslar?) posted correctly...that it seems your question is whether you have a US-spec ( or one of many other "country" spec) cars....or a ROW ( rest-of-world ) car. Not whether you have a Euro or ROW car, as oftentimes they are the same thing.
VIN alone won't help without some cautionary notes given , as some folks gravitate right to the trunk floor area and *think* they are looking at VIN.....when it is only a VIN for pre-80 cars. It is a build number, or "chassis number" thereafter ( for all cars) ...yet it CAN be a VIN for Euro cars. Gets confusing. All post-80's cars will have a trunk floor chassis number with a ZZZ in the middle.....won't mean its a Euro car as US-spec cars will also have the ZZZ there. ( But not on the windshield post or door jamb....where the TRUE VIN is..and where there will be *NO* ZZZ in the VIN if it is truly a US-spec car). So .....what syzygy says [ " Look in the frunk on the passenger side (may be different in RHD cars) for the data plate. WPOZZZ as the first six digits of the VIN = ROW..] .... is not 100% correct for the post-80 cars, as ALL cars will show ZZZ at THAT location. Even US spec cars.
Here's a check. For 1982 *model year*, the ROW engine type was 930/10. For Japan it was 930/16. For USA it was 930/17.
Check alongside the fan support on the topside/flat portion of the engine immediately alongside....to see such "engine type" numbers. There are some similar indicators for chassis numbers...but since chassis numbers and VIN numbers can be so easily confused, the engine type should be a quicker and more certain indicator.
Wil Ferch 04-16-2011 11:06 AM
Engine "type" number can be found here--> see post # 7 within. The serial number shown can be the front face of the vertical fan support, like shown in post #7...or "around the corner" on the SIDE of the same vertcal post.
http://forums.pelicanparts.com/porsche-911-technical-forum/121529-911-engine-codes.html
Wil Ferch 04-16-2011 11:28 AM
Here are pics of my recent US-spec 85 Carrera. Three pics, windshield VIN, door jamb VIN, trunk floor "Chassis number" ( not VIN)....may need to enlarge trunk pic to see this better ( WPOZZZ ...... )
http://forums.pelicanparts.com/uploa...1302978330.jpg
http://forums.pelicanparts.com/uploa...1302978397.jpg
http://forums.pelicanparts.com/uploa...1302978462.jpg
sundevil64 04-16-2011 11:33 AM
switch
A little off topic, but is that a "cut off" switch there? I like it.
Wil Ferch 04-16-2011 12:54 PM
If you mean the O/1 switch?....that's an on-off switch for the trunk light.....for example, when you keep the lid open and don't want to drain the battery.....you know, like most modern cars have.... but is a head-scratcher for electrically-challenged Porsche to include .... :)
Canada Kev 04-17-2011 09:59 AM
Will, you are undoubtedly correct. I've never really paid any attention to the actual numbers on pictures of people's data tags. I can only rely on the ones I have intimate knowledge of (my car). I guess that during assembly, the factory needed a number to identify the cars. In earlier stages of construction, perhaps they didn't yet know the ultimate destination of the car and the final complete VIN that would change depending on where the car was to be delivered. Maybe, only speculating here...
On yours, what are the numbers on the hood mounted stick on option code tag? Are they the ones with the chassis number or your VIN?
Regardless of all this, except for earlier examples (starting from when I don't know) a North American car will have the vin mounted on the A-pillar and in the door jam. My Euro ROW doesn't have these, but has a stamped metal data plate mounted to the inside of the trunk on the passenger inner fender. The option code sticker on the hood also shows the correct VIN. There is another number stamped somewhere in the trunk area, I believe, but I don't remember where off hand.
http://forums.pelicanparts.com/uploa...1303059243.jpg
Wil Ferch 04-17-2011 10:57 AM
Kevin(syzygy) says.... " I guess that during assembly, the factory needed a number to identify the cars. In earlier stages of construction, perhaps they didn't yet know the ultimate destination of the car and the final complete VIN that would change depending on where the car was to be delivered. Maybe, only speculating here..."
Answer...absolutely true.
My paper tag on the underside of the trunk lid shows the proper VIN.
http://forums.pelicanparts.com/uploa...1303063014.jpg
chayanin 09-21-2016 06:37 PM
Thank you for such an informative info. I recently bought a US spec car here in Thailand. Dealer here have no knowledge to differentiate btw Chassis No. and VIN No. Of my car maybe because here both numbers have ZZZ on 4th 5th and 6th digits and 9th digits is usually the same, where as US spec from what I learnt here the VIN number Is slightly different on the above mentioned digits.
Is there a way for me to prove to dealer here that my car is clean and chassis number with WPOZZZ93ZGS050111 is correct and my VIN number WPOJB0931GS050111 is also correct and they are different like that from the factory. Is there a contact person I could write to in official Porsche of North America to verify this for me as of now the dealer here is reluctant to restore my car. Your advise would be very much appreciated.http://forums.pelicanparts.com/uploa...1474508232.jpg
http://forums.pelicanparts.com/uploa...1474508261.jpg
Frosticles 09-22-2016 02:32 AM
Mine has one big difference..................
https://c5.staticflickr.com/8/7726/2...0dbe2c88_b.jpgPorsche 911 3.2 Carrera Sport wheel & dash by Kevin Frost, on Flickr
JJ 911SC 09-22-2016 07:08 AM
Is there a way for me to prove to dealer here that my car is clean and chassis number with WPOZZZ93ZGS050111 is correct and my VIN number WPOJB0931GS050111 is also correct and they are different like that from the factory. Is there a contact person I could write to in official Porsche of North America to verify this for me as of now the dealer here is reluctant to restore my car. Your advise would be very much appreciated...
Chayanin,
From the Red book the "JB0" (and the "0" in the 12th position) in your VIN id your car as a 1986 Turbo US (WPOJB0931GS050111)
J: Turbo Coupe
B: US Engine
O: Active Restraint (safety equipment)
7, 8 and 12th position): Porsche Model Type 930
The 1 in the 9th position in the VIN is a test digit for US & Canadian car (Z for RoW cars also found on the chassis # of all cars)
The matching engine would be type 930/68
From Bruce Henderson book:
That page (especially the last sentence in the red box) should convince anyone that work in this field but sometime it does not...
Good luck,
JJ
https://www.amazon.com/Porsche-911-Red-Book-Specifications/dp/0760347603/ref=sr_1_1?ie=UTF8&qid=1474553118&sr=8-1&keywords=porsche+red+book
https://www.amazon.com/Porsche-911-Performance-Handbook-1963-1998/dp/0760331804/ref=sr_1_1?ie=UTF8&qid=1474553199&sr=8-1&keywords=bruce+anderson
http://forums.pelicanparts.com/uploa...1466068895.jpg[/QUOTE]
javadog 09-22-2016 07:52 AM
Your dealer doesn't have adequately knowledgable staff. The VIN number clearly shows that you own a US car, as the US, Canadian and ROW cars had separate VIN number sequences and they can look in the "V-pages" section of the PET software for the relevant numbers.
The difference in the stamped VIN numbers was addressed in a factory bulletin decades ago.
My suggestion would be to tell them to contact Porsche through their normal channels and ask these questions themselves. It's their job to have all of the asnwers, or know where to get them. You shouldn't have to be the one to tell them how to do their job.
JR
aread 09-22-2016 08:21 AM
http://forums.pelicanparts.com/uploa...1302978462.jpg[/QUOTE]
Not to highjack here, but Will I am dying to know what the switch on the upper left corner of the black shroud is for?
notfarnow 09-22-2016 09:26 AM
Visually, the ROW cars typically have side marker lights on the front fenders, and a red "fog" light under the rear bumper on the left. My ROW '81 SC does anyway
And like others have pointed out, 930/10 engine. That's the fun part
Reiver 09-22-2016 10:39 AM
Motor ID...if it is stamped as a 64DXXXX (x's are the serial number) it is a US 930-16 180 hp.
if stamped 63Dxxxx it is the 930-10 204hp ROW
tcar 09-22-2016 10:49 AM
It's WP0ZZZ (Zero, not Oh).
Not true for the first 3 years of the SC... only 81 and later.
BTW, the '74 (not an SC, I know) had the skinny rear bumper pads in the US.
traknut1 06-15-2020 06:17 PM
Indeed
Bill Douglas 06-15-2020 09:34 PM
Originally Posted by traknut1 (Post 10907168)
Indeed
Hello and welcome to the forum.
You'll have to tell us more about yourself.
ncoder 01-10-2025 01:19 PM
I see the "Europe" term used in the factory manuals.
http://forums.pelicanparts.com/uploa...1736543889.png
The other pages show "USA + Japan" and "California"
ncoder 01-10-2025 01:27 PM
Engine codes:
This is what i got from my the 911 turbo factory manual
http://forums.pelicanparts.com/uploa...1736544256.png
And my engine code sticker shows 93068-68G
So i'm just confused.
ncoder 01-10-2025 01:52 PM
Ah, there's more:
http://forums.pelicanparts.com/uploa...1736545901.png
Although I still don't see my /68
rattlsnak 01-10-2025 02:41 PM
The OP has logged in for over 5 years.. lol.
Schulisco 01-11-2025 08:52 AM
Originally Posted by ncoder (Post 12388675)
Ah, there's more:
Refer to
https://www.stuttcars.com/porsche-911-engine-numbers-1965-1989/
They got the information out of the Porsche original parts catalogue, the V-pages in the front part of it: Porsche listed the VIN, engine and gearbox numbers related to the model years. Saying there's a bidirectional relation between model year vin, engine and gearbox number and you can decode the model year from the number too.
https://www.porsche.com/usa/accessoriesandservices/classic/originalpartscatalogue/#911
Model Region Enginecode MY Code Enginenumber Tech. Displ Power
911 TURBO (USA) 930/68 1986 G 68G 00001>02000 6ZYL/3.3L 3.3L 209 kW 281 hp
911 TURBO (USA) 930/68 1987 H 68H 00001>05000 6ZYL/3.3L 3.3L 210 kW 282 hp
911 TURBO (USA) 930/68 1988 J 68J 00001>05000 6ZYL/3.3L 3.3L 210 kW 282 hp
911 TURBO (USA/CDN) 930/68 1989 K 68K 00001>05000 6ZYL/3.3L 3.3L 210 kW 282 hp
So your 68G is a MY1986 930 US spec engine.
