| al lkosmal |
04-15-2011 09:59 PM |
Often there is a low pressure switch and high pressure switch in the AC system. If either of them trip, they may cut power to the compressor clutch. If you know your way around a Multi-meter, you can check if these switches are open or closed, during operation. However, the switches typically trip to indicate a fault. Low pressure can indicate a system leak and/or low charge, high pressure may indicate blockage, etc....so just replacing switches may not fix a problem. Also....your compressor clutch may be zapping out....either shorting to ground or open. Measure the resistance across the clutch wires. If I remember the resistance will be between 2.5 ohms and 5 ohms. If above or below...it may be clutch time. Also check the continuity of the 12V supply from the thermostat all the way to the compressor. That's all i know...maybe an ac expert will jump in.
regards,
al
