-   -   Cleaning (not polishing, not refinishing) Fuchs? (http://forums.pelicanparts.com/porsche-911-technical-forum/603695-cleaning-not-polishing-not-refinishing-fuchs.html)
jdbunda 04-18-2011 06:22 PM
I am not ready to send them off to Al Reed, and I don't want to change the color, or turn them into gleaming works of art (just yet, anyway) I just want to clean them up!
I have searched without finding anything, apologies for asking what is apparently an obvious question? My just-acquired '86 Targa has some funky neglected Fuchs, the anodized parts are yellowed and crusted with brake dust, and the black parts are charcoal grey.
I need to try Vaseline on the black centers, but the lips need some serious attention. I bought some Mothers' polish, which seemed to work well on a small section, only to read here somewhere that it will take off the anodizing, which is further than I want to go. I tried some "safe for all wheels" Meguiar's wheel cleaner that created spots and left a whitish residue (oops). I see the Porsche wheel cleaner offered by our host in the wheel cleaning kit - for $60 it must be miracle stuff?
So the noob gives up and asks - what should I be using on these things?
TubbyAZ 04-18-2011 06:46 PM
Vaseline on the black nee charcoal centers? Is this really something that will help?
That's the only problem I have with mine, the polished rims look pretty good still.
m110 04-18-2011 07:09 PM
Remove the wheels
place face up
spray with P21S gel:
Pelican Parts.com - Add to Shopping Cart
get a soft bristle hand brush, dunk in water and lather the wheel up, let it sit for a while and rinse
repeat and for stubborn areas add some mechanical action with a mild scrubber foam pad...like scotch brite but milder (detailing places have them, foam covered in a nylon material)
try some isopropyl alcohol for stubborn spots
repeat the P21s
you can try some lacquer thinner but I wouldn't let it set for more than 30 seconds as you work it, rinse
vaseline is ok, I prefer a cleaner/wax
should work
