Ilan's Avatar
Question Drive with no speedo??
I'm getting ready to remove the speedo of my 87 911, and send it in for repair & recalibration. It sticks at the bottom & then jumps to normal operation at about 20-25 mph. If I tap the speedo face while it is sticking, the needle then jumps to normal operation. I'll be checking speed accuracy against my portable gps before I removed the speedo.
My question: Once I unhook the speedo & properly label & insulate the connectors, will there be any disturbance to the electrical system which will keep me from driving the car while I wait for the repair? I plan to use my gps for monitoring my speed during that time.
Ilan Shanon
87 911 white Targa
98 H.D. Roadking
99 H.D. Springer Softail
00 Jeep TJ Sport
Old 02-21-2002, 05:59 AM
Senior Member
Zendalar's Avatar
Well, nothing un-usual, at least not in my -72T. Been driving the whole time without the speedo. You get used to it measuring the speed via tacho.
(Well, my speedo is mechanical
Old 02-21-2002, 06:21 AM
Hilbilly Deluxe
emcon5's Avatar
I drove without mine for a few days when PA speedo was turning my 85mph into a 150 mph, and it didn't seem to hurt anything.
Word of advice, take the rubber seal ring, and use it for a template to cut out a circle of stiff cardboard to use as a plug. You will be amazed at the amount of air that comes through that hole, and it blows pretty much straight at your face.
Tom
82 911SC Coupe
GTI Cup #43
Old 02-21-2002, 09:05 AM
