-   -   74 2.7 CIS Idle RPM Question (http://forums.pelicanparts.com/porsche-911-technical-forum/604344-74-2-7-cis-idle-rpm-question.html)
fuch'd 04-21-2011 07:34 PM
I have a question regarding proper RPM at idle for a 2.7 CIS car. My '74 runs very well, but seems to maintain a higher RPM at idle than it should.
This is currently around 1100 RPM when fully warmed. Can anyone advise the correct RPM (at idle) for this year/combination?
TIA.
Charles Freeborn 04-21-2011 07:42 PM
Mine settles in (when warm) at about 950-1k or so. Depends on weather, stage of the moon, octane, or any number of other non-digital factors.
4sd911 04-21-2011 08:48 PM
Have you tried to adjust the idle by turning the idle screw?
redstrosekNic 04-21-2011 09:25 PM
The stickers under the engine lid should tell you, but my '75 with CIS idles at about 950. I'm pretty sure the stickers say between 900-1000ish. If the idle screw is unresponsive, look for vacuum leaks. 1100 is too high.
