-   -   Window trim finish (http://forums.pelicanparts.com/porsche-911-technical-forum/604875-window-trim-finish.html)
mrm930 04-25-2011 07:18 AM
Window trim finish
Hello all,
Posted this in the 930 forum - but alot more people here.
What have you found to be the best type of finish for the matte black window frames, door handle and glass insert trim to be? Epoxy urethane with a matte clear - or - a matte black powder coat? The only concern with the powder coat is the thickness - especially on the handles.
What have you done and what are your recommendations?
Thanks,
Mark
Mulholland911 04-25-2011 07:58 AM
I had excellent results with powder coating my window trim, door trim and door handles.
McLovin 04-25-2011 08:07 AM
Why not get it reanodized black?
schumicat 04-25-2011 09:30 AM
i had some peeling of the anodizing so I used a couple of coats of black "trim paint" spray you can find at any auto parts store. it is pretty durable as it is designed for this purpose. it is not as durable as powerder coating but only costs $6.
RSTarga 04-25-2011 09:59 AM
I've used the Wurth Satin Black works well although I think powdercoating is the most durable option.
Mulholland911 04-25-2011 10:42 AM
The Wurth paint works great, unfortunately it does not stick well to an anodized surface; I’ve tried sanding and using an adhesion promoter and still have been unsuccessful.
mikeferg75 04-25-2011 10:45 AM
Powder, just find a good man, and explain what you want and to keep it thin.
Annodizing was not a option without drilling out each metal rivet that holds the window channel together, steel can not go into the tank
After pics
http://forums.pelicanparts.com/uploa...1303753532.jpg
