-   -   Valve lash feeler gauges need some checking before use (http://forums.pelicanparts.com/porsche-911-technical-forum/6050-valve-lash-feeler-gauges-need-some-checking-before-use.html)
movin 07-15-2001 12:12 AM
I've noticed that the feeler gauges supplied for the holder sometimes have a ridge at the edge of the gauge, probably due to the die cutting process during manufacture. This can result in a false sensation when using the gauges since the ridge actually makes the gauge measure over .01mm. What I do is hone the edge down slightly to remove the ridge on fine emery cloth.
