-   -   Where can I find 15" fuchs 8" front, 9" rear? (http://forums.pelicanparts.com/porsche-911-technical-forum/605111-where-can-i-find-15-fuchs-8-front-9-rear.html)
JonT 04-26-2011 09:54 AM
Looking for a set of custom fuchs in these sizes with the correct offset for a narrow body SC so I can fit the 225/45/15 and 275/35/15 Hoosiers for track use.
JonT 04-26-2011 08:24 PM
Bump for the late crowd
skinnerd 04-26-2011 10:39 PM
Originally Posted by JonT (Post 5985857)
Looking for a set of custom fuchs in these sizes with the correct offset....
I think you said it all right there.
The factory never made 8 and 9's that will fit under your bodywork, so you'll have to get them custom made.
By someone like Harvey Weidmann, etc.
The likelyhood of buying these off ebay or any other place is simply NIL.
Good luck.
Geronimo '74 04-27-2011 12:53 AM
available sizes.
944racing
Whether you can fit them under a narrowbody is another question....
Anything can be made to fit, but how much work are you willing to do?
Bill Verburg 04-27-2011 03:52 AM
Jongblood are pretty popular around here
Gary R(& a few others) just put the, on their cars also using the 225/275 HoHos
http://forums.pelicanparts.com/uploa...1303901437.jpg
http://forums.pelicanparts.com/uploa...1303901464.jpg
http://forums.pelicanparts.com/uploa...1303901479.jpg
There are several other choices too
Simmons
Work
Buckley
PcarPhil 04-27-2011 04:11 AM
If you want to go custom you can get a set of 6x16 Fuchs centers cut and drilled for 20 bolt BBS shells, then use 15" flat BBS shells to make up the wheels.
If you want to go factory I've seen a handful of narrow cars running OEM 8&9x15 Fuchs wheels. The offsets are not exactly what you'd what but they can work with 225/275 Hoosiers.
I've got a set of 8&9x15 Fuchs I'll consider selling but they're far from cheap. Your best bet is to make up a set of custom Fuchs using BBS shells.
http://forums.pelicanparts.com/uploa...1303783938.jpg
group911@aol.co 04-27-2011 07:18 AM
Good luck.
I had a set of 8's and 9's on my 75 Carrera in 1977 so they do fit.
Tire sizes may be another matter.
Seems like I used 225/60 CN 36 up front and 235/60 on the rear. Biggest thing available at the time.
skinnerd 04-27-2011 07:46 AM
If the "stock" 8 and 9's do in fact fit, here's the story for factory Fuchs.
The 15x8" are fairly common on eBay.
$600-1000/pr commonly.
The 15x9" are another story.
See those on eBay occasionally for $3-4k/pr.
So that's your dilema.
While fronts are reasonable cost, real 9" in the rear are very expensive and hard to come by.
A good wheel builder should be able to build you a set for the back for much less....
Ducman 04-27-2011 08:04 AM
I think Baird make a 15 x 9 "Fuchs" in the correct offset for sc rear. Don't know about front 8" though
euro911sc 04-27-2011 08:49 AM
The standard 15x8 does not fit the front very well at all. I would say it doesn't fit, but people seem to run them anyway. I have a set... the offset is very wrong and as far as I have researched they all come with the same offset. I really would love to be corrected here, but so far I have not been. Ideally I want to run a 15x8 fuch front w/ 15x9 minilite rear... ;)
So... both front and rear would have to be customized if you wanted to run Fuchs (because 15x9 fuchs are hard to find and very expensive when you do... see above post).
Then there is the tire selection pain...
-Michael
Bill Verburg 04-27-2011 10:52 AM
Do you recall the o/s? It must have been very tight at the lips, the ET3 9s stick out 12mm more than the later ET15 9x16
same w/ the ET10.6 8s, they stick out 12.7mm more than the usual 7ET23.3
Back in those days the available 9x15 had ET3 and had part # 911 361 020 06 & 911.331.012.05
there was a 2 9x15 part # 911.361.020.03 as early as 7/73, but I always thought they had ET3 too.
Bill Verburg 04-27-2011 10:54 AM
-Michael
I agree 100% the standard 8x15 911 Fuchs has ET10.6 and sticks out to far when used in front unless you have turbo fenders
8" fronts need ET25-30 +/-
group911@aol.co 04-27-2011 11:36 AM
Bill
My 75 Carrera had the standard lowered suspension for the time and really no problem on 8" fronts.
No idea on the offsets for the 9" rears but they were just off the shelf new in 1977.
All I know is I sold them way too cheap.
PcarPhil 04-27-2011 11:59 AM
Another picture:
http://forums.pelicanparts.com/uploa...1231858088.jpg
PcarPhil 04-27-2011 12:36 PM
For the OP the 6x16 Fuchs wheel centers would look like this:
http://forums.pelicanparts.com/uploa...1225641638.jpg
http://forums.pelicanparts.com/uploa...1239823627.jpg
http://forums.pelicanparts.com/uploa...1278262752.jpg
And the shells (barrels) would look like this:
http://forums.pelicanparts.com/porsche-911-used-parts-sale-wanted/527577-fs-bbs-e50-magnesium-core-race-wheels-15x11-15x9.html
http://forums.pelicanparts.com/uploa...1266796781.jpg
http://forums.pelicanparts.com/uploa...1266796812.jpg
Bill Verburg 04-27-2011 01:16 PM
Originally Posted by group911@aol.co (Post 5988355)
Bill
well all the 8s in those days were ET10.6 and the only 9s I have ever seen or heard of were ET3
So you moved the rear 8x15s to the front and bought 9x15? Wish I had a chance to see it up close. That is a fitment i'd never believe would work on a Carrera body. Not to doubt you but I still don't.
The usual fitment in those days was 7 & 8 x15 w/ 205/50 & 225/50 tires, at least that's what my '76 C3 came w/. I did use the same 7 & 8 wheels on my '72 RS clone but w/ 215/60 & 235/55 tires, and the 215s were hard to fit that was my first experience shaving lips.
to anyone else out there, please post pics of 911 8ET10.6 on the front of a Carrera body if you have them and also any of you that have 911 8s w/ spacers on a Carrera body. 930s please do not post we know they will work for you.
JonT 04-27-2011 01:27 PM
Thanks everyone--Scott--what is the offset on those custom fuchs you have there?
group911@aol.co 04-27-2011 03:18 PM
Actually, 75 Carrera's came with 185/70 and 215/60 when new. Dunlops on mine but Pirrelli's on others.
I need to dig up old slides of the car with them.
Bill Verburg 04-27-2011 03:59 PM
I understand that
stock on all Carrera's from '73 to '77 was 6 & 7 x15 w/ 185/70 & 215/60 usually Pirelli CN36
by '76(probably earlier but I don't have the complete documentation for '73 -'75) 7 & 8 x15 w/ 205/50 & 225/50 was an option, tires were Pirelli P7. For '77 C3 there was an additional option of 6 & 7 x16 w/ 205/55 & 225/50 tires
group911@aol.co 04-27-2011 05:15 PM
Originally Posted by Bill Verburg (Post 5988997)
I understand that
Bill
For US Carreras, 7&8's became standard in 1975. 6&7's were in fact standard on the 74 US Carreras
Bill Verburg 04-27-2011 05:32 PM
Originally Posted by group911@aol.co (Post 5989166)
Bill
For US Carreras, 7&8's became standard in 1975. ..
Ok, I just looked that up and yes, I agree.
skinnerd 04-28-2011 12:18 AM
Originally Posted by Kaefer (Post 5988428)
To me, the only way 8 & 9's std offset work are to use less than optimal width tires along with jacking the car up to a higher ride height.
See photo above....
Shaun @ Tru6 04-28-2011 01:28 AM
9x15s do not fit in the rear unless you are at Paris Dakar ride heights.
Had to sell them, sad day, should've kept'em. at least they went to guy building an honest IROC tribute car.
http://forums.pelicanparts.com/uploa...1303979310.jpg
HARVEYWEIDMAN 04-29-2011 07:05 PM
See photo above....
Please don't assume Rob's car has stock fenders or standard offset wheels...
He is the master of illusion...
Yes, we can and do build 8&9s to fit RS style rear flairs and stock front fenders...
H
Shaun @ Tru6 04-29-2011 07:12 PM
H
But what about 9x16 cookie cutters? :D
I should have the flares done next weekend (pre-flare below)
http://forums.pelicanparts.com/uploa...1270074805.jpg
HARVEYWEIDMAN 04-29-2011 07:16 PM
I have not found a suitable 16 donor for the cookie cotters, unless we cut up a 8X16 Fuchs.. $$$$. Or ugly BMW lips..
H
Shaun @ Tru6 04-29-2011 07:21 PM
that's a shame, PM sent.
gumba 04-29-2011 09:55 PM
Why not go with 8"(944 turbo) & 9 x 16's? The Hoosiers tire height is the same as the 15's.
clutch-monkey 04-29-2011 10:46 PM
as mentioned, looks like the Braid wheels will suit the width you're after but they only list std offset.
http://www.braid.es/wheels/products/competition-wheels_p8/special-design-wheels_p18/bz-15_p172.html
i've got 8's up front and 9's on the rear on my car but i played with the offset for my fikse wheels.
Bill Verburg 04-30-2011 04:08 AM
what do you consider to be stock 8 & 9 o/s?
Bill Verburg 04-30-2011 04:29 AM
Baird 9x15 has ET-3, Great for a turbo rear but not for an SC/Carrera
their 8 is ET 10
Despite Group 911s claim and as much as I respect him, they do no fit on the front of an SC/Carrera body 911
In the front of an SC/Carrera body car 7 ET23.3 was a factory fit and is tight, 8 ET 23.3 can be used but is extremely tight and will require lots of fender work at any reasonable ride height all aftermarket 8" fitments that work well are ET25-31
in the back 8" ET10.6 was a standard factory fit, 9ET15-12 is a known good fit(ET15 is the standard 9x16 Fuch, lower ETs are getting more aggressive) The only 9x15 factory Fuchs I have ever see all have ET3 and were used on the '74 Carrera 3.0RS which has turbo flairs,
The Jongbloods seen here are 8x15 ET25.4 w/ 225/45 & 9x15 ET12.5 275/35
Bill Verburg 04-30-2011 04:44 AM
To the best of my knowledge there were no 9 x16 Cookie cutters, they only came in
5.5 ET42 901.361.017.00
6 ET36 911.361.023.44
7 ET23 911.361.023.54
Todd Simpson 04-30-2011 05:10 AM
To the OP, check out this thread-
http://forums.pelicanparts.com/porsche-autocross-track-racing/587207-8-fuchs-up-front-sc-race-car.html
"newms" is using factory 8's in the front and custom 9's in the rear. Hopefully he can share his source for the 9's.
You'll notice the 8's in the front just don't fit, but it seems you can get away with such a short tire and you don't mind the wheel sticking out from the fender.
No....The 15's are 22.9" and 23" tall, the 16's are 24.7" tall. That provides a gearing advantage for those that must use stock gearing for racing.
Bill Verburg 04-30-2011 06:29 AM
Apparently Mike is too, he says that these are 8ET10.6
http://members.rennlist.org/analogmike/car911rs.jpg
