What's this VIN #
I have two VIN numbers I cannot identify...hopefully someone can.
I'm rebuilding a 911 and have this number on the engine fan on my 3.0 replacement engine. Can anyone explain this number: 930 106 102 OR.
Also, I've replaced the rear "clip" and have this VIN 911 006 512 07
Old 04-25-2011, 08:36 PM
Easily Confused
dtxscott's Avatar
The "OR" is actually "0R"
It is a number used for castings and is not an orderable number. It is an internal number used by Porsche for assembly.
According to PET, the 911 006 512 07 comes back as a tire pressure sticker for a 1976 USA/Canada 911S
Scott C.
'08 Cayenne GTS 6MT : '89 Targa GP White/Black - "Oliver's Car" : '11 Mitsu Evo X : '08 Lexus IS350 F-Sport : '01 Toyota Sequoia : 1998 Yamaha V-max : 1979 BMW R65
Old 04-25-2011, 08:53 PM
83 911 Production Cab #10
JJ 911SC's Avatar
930 106 102 0R Part # for Fan Housing
911 006 512 07 Part # for Tire Pressure Decals
In the case of a Casting, their part # seem to finish with "#R"
For other part, the last two "##" is the Revision number
In the case of the Decals it goes from "00" to "09", funny there seem to be 2 "03" but no "04"
Pelican Parts - Automotive Parts and Accessories - Porsche & BMW
Who Will Live... Will See
Old 04-26-2011, 02:27 AM
VIn# Thanks
Scott,
Thank you for the help. Parts #...should have got that. Will the engine have a VIN# stamped on it?
Thanks,
Dan
Old 04-26-2011, 08:12 PM
Easily Confused
dtxscott's Avatar
It will have a number stamped on a vertical face next to the oil pressure sender unit. It resides below the fan and is visible from the right hand side of the engine when facing the front.
It will have a * and then some numbers.
The stamped number will not be a VIN number. It will be a series number that tells you what kind of engine it is.
On my '89, there is a decal on the bottom of the engine with the car's VIN number printed on the decal. I'm not sure about your car.
BTW, you may have to bust through some cosmoline to find the sticker.
Scott C.
Old 04-26-2011, 08:37 PM
