-   -   Help: Brake fluid overflow line (http://forums.pelicanparts.com/porsche-911-technical-forum/605293-help-brake-fluid-overflow-line.html)
mojarra2929 04-27-2011 03:17 AM
Hello
I just had my car painted and found out that the brake fluid reservoir overflow line has not been properlly installed.
Can you please tell me the factory path for that hose?
My car is a 911 carrera, 915 transmission, year 1985.
Wil Ferch 04-27-2011 05:11 AM
It basically runs the length of the fender ( near the shut line with the trunk lid) toward the front of the car.....and escapes to the outside thru a difficult-to-find opening near the front of the main chassis, somewhere in the vicinity of the front suspension pivot. This small diameter line is "captured" by a bent metal tab on the outside of the car to hold it in-place. Follow the fog light wires backwards from the lights.... until the point where the wire penetrates the main chassis, and this small clip holding the overflow line will be nearby. Perhaps some here have a pic?
moneymanager 04-27-2011 07:06 AM
Better to run it to a small plastic bottle below the reservoir then drain the bottle every couple of years.
m1franck 04-27-2011 03:56 PM
You can get a small plastic bottle like this at Harbor Freight. Also, make sure to use tubing that is rated for brake fluid. Brake fluid is nasty stuff and it will bleed through hose that's not up to the task.
http://forums.pelicanparts.com/uploa...1303944934.jpg
James Brown 04-27-2011 04:23 PM
Hey M1, aircraft mechanic?
m1franck 04-27-2011 04:27 PM
Not me, but I've picked up on habits from my father and brother, who are both pilots and fly for a living. I tried, but never caught the bug like them.
In fact, I still have, covet and use a pair of safety wire pliers my father gave to me as a gift many years ago.
James Brown 04-27-2011 04:41 PM
nice work, I am and it's a good habit!!
