Sponge seal
This piece came from forward & above of engine tin seal. I've looked in the parts catalog without success. Any help would be appreciated.Thankshttp://forums.pelicanparts.com/uploa...1304116804.jpg
It gets stuffed up along the fuel lines and around the shock support. I think its installed to keep the flow of cold air above the sheetmetal. In the pet its called a strap,
911.504.930.00 but in the picture it fills the bill.. Bruce |
911.504.930.00
Its a foam block between the chassis floor pan and a shock mount bar Bruce |
Flat6pac,
That's it Thanks |
Going to use A/C insulation line foam from HD to stick there shortly :D
| All times are GMT -8. The time now is 06:11 PM. |
