opinions on mallory box vs msd?
any opinions on this thing? Other that looking cooler it seems to do the same thing.
Mallory 6853M Mallory Hyfire 6-Series Digital Ignition Systems Also is there a difference on the install of the new MSD 6al digital than the original?
1976 Porsche 911s-Balanced and blueprinted 2.7, Rennsport bilstiens, 21/27 hollow tbars, rennline strut brace/strut monoballs, poly front bushings, neatrix rear bushings, Hawk pads, SSI's, M&K 2 in 1 out, 15x7 fuchs wrapped with yoko s-drives, turbo tie rods, steering rack raiser, and JL stereo. Avid national kart competitor at the sharp end of the field-sponsors welcome |
I was using Mallory Hyfire 6AL boxes for several years. I had 3 of them fail over the years including the last 2 in moments after installation. I've switched to MSD for reliability.
-Andy
72 Carrera RS replica, Spec 911 racer |
nothing wrong with the original bosch unit, unless it's dead.
That's not quite true, John. The OEM CDI unit is 'way to subject to system over-voltage events. A poor connection, a few milliohms, between the battery, all the way up front, and the alternator/regulator back there with the engine (and the CDI) and the alternator will need to put out >15 volts in order to get 13.5 volts to a fully discharged, almost fully discharged, or heavily LOADED, battery. It really truly needs a voltage dropping resistor and a powered zener diode to prevent voltages above ~15 volts from doing damage. If the factory CDI input voltage rises much above ~15 volts then the unregulated output voltage of the DC-DC up-converter (inverter) will exceed the "avalanche" voltage of the SCR. The CDI then begins to "self-fire" above the rev limit (tach "jumping"), the rev-limiter then activates and LATCHES due to the >15 volts and the engine remains STALLED of fuel until the ignition is switched off for 3-4 minutes. Same can be said for the rev-limiter that latches up if the system voltage spikes above ~15 volts. |
I fried mine due to over voltage.
Never disconnect the battery with the engine running. Chris 73 911 E |
I've never had one fail in 35 years. Original Bosch. If you don't have one go MSD but you'll have to get your tach modified.
1973 911S (since new) RS MFI specs 1991 C2 Turbo |
Almost Banned Once
I find it amusing that Mallory have used "6AL" as part of the name of their product.
Why couldn't they think of something original?
- Peter |
Fleabit peanut monkey
RETIRED
BOSCH works good fer me.....
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
I am testing a new CD from Daytona-Sensors. Really a relable and modern unit.....
No Tach modification, Data logs RPM, advance, boost retard. And you can lock your distributor and build the advance into the box by programming it with your laptop. AND it come with its own tranformer type coil.....all for $600 neighborhood. When I am done with my tests I am going to try to talk Pelican into carrying it. Will keep you posted.
RGruppe #79 '73 Carrera RS spec 2.7 MFI 00 Saab 95 Aero wagon stick 01 Saab 95 Aero wagon auto 03 Boxster 90 Chevy PU Prerunner....1990 |
You've done the MTBF calculation...?? The only real proof of reliability is widespread use/testing over time, lots of TIME. |
I have been running the Mallory in my 914/6 for over a year now with no issues. It is digital vs. analog for the MSD.
2002 Boxster S . Arctic silver + black top/int. Jake Raby 3.6 SS engine " the beast ". GT3 front bumper, GT3 side skirts and GT3 TEK rear diffuser. 1999 996 C4 coupe black/grey with FSI 3.8 engine . Rear diffuser , front spoiler lip with ducktail spoiler . |
