-   -   951 fuchs on a 911 ? (http://forums.pelicanparts.com/porsche-911-technical-forum/606397-951-fuchs-911-a.html)
carrera1 05-03-2011 09:25 AM
Do the fuchs from an '86 951 work on a 911 ?
16x7/8
Anyone using this configuration ?
thanks
Bob Kontak 05-03-2011 10:09 AM
This excerpt from Bruce Anderson's book has some info but does not identify year.
Porsche 911 Performance Handbook - Google Books
In the search - advanced search function load in some search text like "wheel offset" and isolate on the 911 tech forum. Then grind through the posts. The search function does not recognize numbers so it's tough to get specific.
djcdmv 05-03-2011 10:26 AM
A few places to try:
Originally Posted by Jeroen (Post 5746572)
here's a list with all available Fuchs sizes
it nicely shows the off-sets and backspacings, so it might be helpful
http://forums.pelicanparts.com/uploa...1293319152.jpg
found in this thread:
http://forums.pelicanparts.com/porsche-911-technical-forum/567149-wheel-spacers-widebody.html
The thread has some mention of the 951 Fuchs (check out post #12)
Search out Wil Ferch or Bill Verburg... they both seem to know a ton about wheel offset/backsize and spacers.
RoninLB 05-03-2011 10:34 AM
I use 951 7x16 on a narrow body all around
http://forums.pelicanparts.com/uploa...1304444077.jpg
darrin 05-03-2011 10:37 AM
I believe that the 951 7x16 have the same offset as the 911 7x16 wheels, but have additional brake clearance.
The 951 8x16 have a different offset that allows them to be run up front on a 911 with wider tires.
SO -- the 951 8x16 are good front wheels for a 911 and you'd really want to track down a pair of 911 offset 9x16s to run in the back with appropriately wide rear tires.
Bob Kontak 05-03-2011 10:59 AM
They don't give them real 9X16's away as you probably know. They sure look nice, though.
don911 05-03-2011 11:24 AM
Here's pictures of my car with 951 - 7/8s
http://forums.pelicanparts.com/pacific-northwest-us-wa-id-ut-hi-ak/584266-7-8x16-fuchs-sale.html
jurhip 05-03-2011 01:14 PM
carrera1 - I have 951 fuch's (7&8) on my '87 carrera. They fit fine w/o spacers, but the backs do not fill out the wheel well the way a normal 911 8" fuch will. (note - the PO rolled the fender edges)
Technically, you can put 1/2" (12.7mm to be exact) spacers in and you will have the same rear track as with 8" 911 fuchs. However, they will not look the same since the wheel design is different (not as dished).
