window trim hardware?
I've misplaced the hardware for my door glass frames and the quarter glass frames. Do you guys know what size the the small flat head counter sunk screws are that hold the frames together?
77 911 S TIA Jason |
I think one of them is a rivet obtainable from out host.
W |
Check out page 249 of this parts pdf. It shows an "tapping screw" (#28-1) with 30 as the quantity. It gives the size and part number,
http://www.porsche.com/all/media/pdf/originalparts/usa/911_USA_74_77_KATALOG.pdf If that is not the part sniff around in there and find it. Porsche normally provides the size. Here is the parts link if this is the one. Don't forget the washers. Pelican Parts - Product Information: OEM-90014508100 |
Thanks for the response. The quanity sounds correct but the diagram is not very detailed.
| All times are GMT -8. The time now is 03:21 PM. |
