Take the Drip'in Oil test!
Honestly, just how little or much oil does your pristine 3.0 SC's drip after setting unstarted for: 1-month - 3-months?
A) None ... Not mine. Well not since the $10K overhaul. B) I'd say just a little, maybe toward the front at the split halfs. A teaspoon tops. C) Evidence of some very minor drippings down onto heat exchangers.. but just a little mind you D) Can't tell cause my motor is dirty man. Take the test n post your answers Just for the health of it. Cheers Antares |
Few drops under camcover seals...
Thank you for your time, |
D
but i like the smell of burning oil............... ![]() oh yeah, sorry mines an '86 does that count??
Rich ![]() '86 coupe "there you are" |
Almost nothing only a slight wetting under the cam covers.
-77 911 with eurospec 3.0, 204 hp engine.
Bjorn, 911-65 911-77 |
Senior Member
Here's a datapoint for a daily driver: none, period. I park it on top of a 5'x3' white-faced board (came with the IKEA desk; great stuff!) and there is nary a drip on it.
It can be done! John
'78 Targa in Minerva Blue |
My '83 sits in the garage between December and April, and hadn't leaked as of last weekend anyway. The only leaking problems I have had, actually, came not from storing the car but from a bad oil cooler and then from the return tubes. Then again, the PO (I've had the car for about 7 yrs) had gone through the engine pretty good, so maybe I'm due for some problems this spring...
'83 SC Targa '87 944 Turbo '08 Cayman '10 Boxster S |
Sitting for 1-3 months unstarted.
You are joking right
Clark Retired, I'm now posting under my real name Chuck Moreland Day Job - Elephant Racing Basic Transportation - '86 Cab - "Sparky", '77 Targa - "The Peaper" |
Unregistered
My 80 SC doesn't sit that long, but if it sits for two weeks, it will leave exactly two drops on the floor. One is from a right lower valve cover nut and the other is from a hose that weeps a little. That is with just over 100,000 miles on the original never rebuilt motor. I plan to take care of one of those drips soon, but the other I guess I can live with :-)
