RS door panels from Orignal Fit Int..
Has anyone got any hands on with these?? I have just gotten some and they are indeed light. and in many pieces.. how do the build up and hold up. I will be installing these tonight and was just wondering what i'm instore for .. do they mount up easy.. ? just wondering any helpful insight would b e great
Nobody
they're a bit mousey, as compared to the opriginals, but they look ok when installed. the red pull is lighter weight. on early cars (before 74) you need to install the later pivot assembly that the inner plastic door release handle would pull, as well as the long rod between it and the latch.
does this come with the Kit or is this something I will have to get and if so .. where can i pick this up??
