maresdesign's Avatar
Center Fill Fuel Tank - Ground?
I've bolted in my tank, all new lines, pump etc. My question is: Does the tank require being grounded to the car?
Old 05-08-2011, 07:44 AM
Old 05-08-2011, 07:03 PM
Crusty Conservative
silverc4s's Avatar
If you have bolted it to the chassis resulting in metal to metal contact - not painted surfaces - then it is grounded. Your metal chassis is also electrical ground for your car.
Bill
69 911 T Targa, 2.4E w/carbs (1985-2001)
70 911 S Coupe, 2nd owner (1989- 2015)
73 911 T Targa, 3.2 Motronic (2001- )
Old 05-08-2011, 07:29 PM
The tank has new paint as does the trunk. The tank perimeter seal is new as well. I think I'll just run a ground wire off the spare tire stud to the body. (went to the diagram and found there is a ground from the filler neck to body)
Old 05-08-2011, 07:46 PM
