Order Online or Call:
888-280-7799
McAfee SECURE sites help keep you safe from identity theft, credit card fraud, spyware, spam, viruses and online scams
Porsche | BMW | Mercedes | Audi | Volkswagen | Saab | Volvo | Mini
  Search Pelican Parts:
View Cart | Project List | Order Status |  Help
Freybird's Avatar
Tachometer died
Tach part number 911 641 301 05
On a spirited drive Sunday morning the tach suddenly went to 0rpms. Everything else was quite normal. When I shut the car down, the tach did blip up to 1000rpms and then back to 0rpms.
I've searched all over these forums and found instruction on removal and disassembly of the sealed tach case. Upon opening, the smell of fried electronics was evident. The resistor circled in the picture is burned open. (sorry for the bad cell pic) Appears to be 100ohms, but its too roasted to tell definitively. Does anyone know the actual value of this resistor or where to find a schematic? This tach has the 7pin connector on the back.
I'll be monitoring the charging voltage tomorrow as I suspect this is what caused the failure.
Thanks in advance for any information.
'86 911 Coupe Corner bal track aligned, Toyo RA1's
'87 Mercedes 300 Turbo Diesel-'95 Mercedes na 300d diesel-'97 Cannondale super V700
'02 Dodge Ram 1500 4x4-'11 Rancilio Silvia w/PID
'84 Toyota Pick-up 4x4 (Sold)-'79 280zx ported, ralley cam(sold)
"Wisdom begins with calling things by their real names; A is A.
Old 05-09-2011, 06:52 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #1 (permalink)
Freybird's Avatar
Update:
I see 14.3vdc at the battery at idle and solid 14.0vdc at the cigarette lighter with engine revving. (lights on and off) I suspect this to be normal. (?)
I'm now suspicious of my external battery charger. Stupidly connected and disconnected the leads while in the "Start engine" position.
Perhaps someone has an opened Tach and could provide the color code of the resistor.
Thanks again.
Old 05-10-2011, 05:30 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #2 (permalink)
sc_rufctr's Avatar
I may be able to help but not for about 24 hours. I opened up a tach for a 78 and I may be able to find it in the garage.
I'm away from home right now.
Peter
1994 VW Golf VR6 ~ 1978 911 SC - 3.1L "Kruger".
Old 05-10-2011, 05:38 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #3 (permalink)
Freybird's Avatar
Thanks so much Peter! That would be great!
Old 05-10-2011, 06:37 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #4 (permalink)
wwest's Avatar
Originally Posted by Freybird View Post
Update:
Thanks again.
Look it over closely for a leaking, oily deposits nearby, or bulged out electrolytic capacitor. Very common initial failure point for electronics assembly subject to extraordinary heat.
Old 05-10-2011, 07:40 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #5 (permalink)
Freybird's Avatar
Thanks W! I've checked it over again and found all caps to be in good shape. This is a little surprising considering the intensity of the burned smell or "Essence of Allen-Bradley".
Old 05-11-2011, 07:09 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #6 (permalink)
Freybird's Avatar
Using a 100k, 50k, and then a 1k ohm potentiometer, I decreased the resistance until the tach came to life. With the 1K pot in the circuit, 350 ohms was the magic resistance. 330 ohms is the closest common value.
So I believe the answer is: 330 ohms
I will solder a 2W resistor onto the board, reassemble, and test.
Old 06-03-2011, 03:59 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #7 (permalink)
sc_rufctr's Avatar
I'm glad you worked it out. I couldn't find that tach from my 78.
Peter
Old 06-03-2011, 05:31 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #8 (permalink)
Frey - Did the resistor work?
Frey, I have the same issue with my 86 911 tachometer. I cracked it open and found the resistor fried. I bought a 330ohm (2W - which is huge, I may drop it back to 1W), but no luck. I can't find anything else wrong (at least no obvious component failures) but the tach won't come back to life. I've verified the signals are correct to it as well. Did you find anything else wrong or did yours work after the resistor change?
Old 08-16-2012, 03:49 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #9 (permalink)
Freybird's Avatar
'm wondering if each tach is tuned differently and hence this resistor is different for each tach.(?) I found only this resistor to be the problem in my case. You may wish to troubleshoot as I did. Get a potentiometer (1k ohm I believe) and connect it in place of the fried resistor using alligator clips. With the car running and everything connected, turn the potentiometer down slowly, decreasing resistance from 1k ohms until the tach comes to life. Shut it down, disassemble, and read the resistance of the potentiometer. (you could also keep the pot in there if small enough to fit in the can. Super glue the shaft to keep it from rotating.)
Old 08-18-2012, 05:45 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #10 (permalink)
Copyright ©2000 - 2013, vBulletin Solutions, Inc.
Copyright 2011 Pelican Parts - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
