Guest
Posts: n/a
I can hear my clutch engage...!
I can hear my clutch engage after I take it out of gear (neutral) and then release the clutch again, it sounds like two pieces to metal coming together (klunck). Now shifting in general is OK, a little notchy between 1st and 2nd, but thats it.
Is this a one of the many interesting "Normal" sounds from a 911 or should I be worried... Car is still on its first clutch with about 54k on the clock. Gruß Sebastian |
You may have simpley gotten a clutch that has the rubber Center that has rotted and now the clutch engaging is more noticeable.. I wouldn't worry too much unless you begin to have problem's selcting a gear or the clutch begins to have pronblems engaging..
