will h5s fit 74 targa
does anyone know if the h5s will fit into the 74 fender
RETIRED
Don't see why not.....
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
Insert Tag Line HERE.....
yes..
They will fit, the only change you need to do is the connector, you have a connector that fits sealed beams and H4s. The connector for H5 is different. You can buy an H5 connector and use spade contacts to adapt it to the H4 connector.
h5s
thank you very much for the info gentelmen.
dave |
They will, but they're worthless. Go for H4's. H5's are plastic and can't use high wattage bulbs.
1973 911S (since new) RS MFI specs 1991 C2 Turbo |
Mike Holbrook
Unless they are basically free, why go that way. H4's are a better system for our cars.
Mike Holbrook Meridian, ID 1979 911SC Targa |
