Cannot locate hardware - any ideas?
Hi All –
I am stuck and was hoping to find some help. I am just about ready to put my new motor in the car. I just realized that my engine case does not have the transmission mounting studs. I used bolts to hold it to the engine stand and it never really occurred to me they were missing – until now. I have searched high and low and cannot find a source for these parts. The part numbers are as follows: - Two lower mounting studs: 999 061 034 02 (M10x67) - Starter mounting stud: 999 062 110 02 (M10x115) - Top Bolt: 999 062 165 02 (M10x75) Can anyone point me in the right direction on locating these parts? Thanks in advance – Scott S Colorado |
I'd check the usual suspects, LAPD, Parts Heaven, Dave at TRE, John Walker.....
did your search include pelican parts? it has 2 of the 3 if you paste the part number.
hmmm. that is strange. I called an spoke to them and they said NLA. I will make sure I did not botch the part numbers I gave them...
Parts
Second and third parts are available here at Pelican.
found my brake bolts here in a hex head (vs allen head)
Bill K Bolt Depot - Fastener shopping made easy http://www.boltdepot.com 1-866-337-9888 |
figures - I finally break down and post this thread and locate everything within 2 hours of doing so.
Found what appear to be the last three bottom studs in the dealer network in New Jersey. I bought all three they had on hand just in case I mess one up. And yes - you guys are correct - at least the starter stud seems to be available at PP. Calling them to verify right now. Thanks for setting me straight! |
Locally in Denver is AAA Metric Supply Inc. "AAA Metric Supply" They have a walk up counter and are even open Saturdays, they are on Lipan. They will have them.
