Tool for gas tank drain plug porsche 930 1983
Hi
Can anyone tell me what tool i need for the gas tank drain plug situated under the front end of my car under the gas tank? Its like a LARGE hex fitting looks like it needs a male type fitment .I certainly dont have an allen key that big and the spark plug removal tool looks and fits the right size but i cant get any grip on it . Many thanks |
i'm sure they make an allen large enough, but i wouldnt want to pay for it.
i took a bolt with a head that fit perfectly (17mm?) and double nutted a few NUTS to it. then i just jabbed the bolt head into the plug like a big old homemade allen head and used a box wrench on the "locked"nuts and twisted it off. it was pretty easy, and i still have my "tool" rattling around the top shelf of my tool box.
poof! gone |
vash that sounds just what i need
you got a pic of it ? im a visual person ,thanks for suggestion .
i believe a 13/16" spark plug socket that has the hex area (like craftsman) upside down fits then you can put on an extension and ratchet
i'll take one tonight, if you dont have it worked out.
poof! gone |
175mph951
i have one of those but as you say the hex end is where u put the ratchet ? do you mean put the extension bat through the round open end into the hex end the wrong way round like a sleeve ? i didnt know that would fit |
Thanks gents ive done it !
managed by using the 13/16 with a smaller spark plug remover coupled together then the extension wrong side through.bit of a cobble together but it worked . the gasket ? does it defo need replacing when refitting ? |
