Order Online or Call:
888-280-7799
McAfee SECURE sites help keep you safe from identity theft, credit card fraud, spyware, spam, viruses and online scams
Porsche | BMW | Mercedes | Audi | Volkswagen | Saab | Volvo | Mini
  Search Pelican Parts:
View Cart | Project List | Order Status |  Help
Binge User
Schrup's Avatar
80 SC Reassemble Help
For a variety of reasons, my SC has been in my garage mostly disassembled for the last 5 years. I've spent the last few days getting things put back together. I'm using this forum, Wayne's book, & my Bentley manual to help figure it out. I've got most of the stuff back on the car, gas tank, oil tank/lines.
Now I'll be working on getting my engine reassembled & ready to put back in the car. I can fore see some problems, but hope they're not as bad as I make them out in my mind & try not to worry about them till they come up.
Two parts are of concern at this time. The first is my fan mounting strap. I wasn't careful when I removed it thinking I would replace it. Well, the days of milk & honey have dried up & I need to save as much money as possible. I'm not going to doll up my fan & housing at this point. Is my strap still usable?
Second item is my engine mounting plate. It is missing one of the tabs where the engine tray mounts. I can see the old spot welds where it was, but I can't seem to find the tab. I'm not sure it was even on there when I took it off. Is this something I should be concerned with or can I go ahead & paint it?
Any help is greatly appreciated.
Paul
Old 05-13-2011, 04:06 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #1 (permalink)
howard freeman's Avatar
Both parts are easy to repair. Make a new tab & weld it on the mounting saddle. Did the bolt pull thru on the fan strap?? I not clean it & paint it & install it.
Howard
Howard Freeman
80 911 SC & 74 914 1.8
79 930 & 83 SC coupe
03 X/5 3.0. 246,016 miles daily driver
03 745 I 142,312 miles road car
Old 05-13-2011, 05:11 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #2 (permalink)
Binge User
Schrup's Avatar
Thanks, bolt didn't pull through, just kinked the band. Will clean paint & install. I really think the tab was missing already or else I would have it. I think I'll push ahead unless I run across it. After I mock it together, I may make a tab if I feel it will cause a rattle.
I have massaged my head studs with some PB Blaster & a newer exhaust nut. Only one was balky, spent about 10 minutes working the nut back & forth until I got it to go on smooth. John Walker replaced one of the studs that unscrewed for him when he installed my SSIs. He also made some spacers out of old exhaust nuts by drilling out the centers. If I coat the entire stud with antisieze, will it prohibit rust were the spacer is? Or should I just apply it to the top where the nut will go because it will burn off the rest? How do you guys determine the torque at such weird angles? The Bentley says 18# of Torque, I'm really nervous dealing with these studs.
Paul
Old 05-13-2011, 05:37 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #3 (permalink)
Use a good antiseize like lubro moly LM508 & torque to 15-18 ft lbs& use new copper nuts & new barrel nuts & you won't have a problem.
Howard
Howard Freeman
Old 05-13-2011, 05:49 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #4 (permalink)
Binge User
Schrup's Avatar
Thanks Howard. I installed the oil cooler with new seals, oil line & adapter. I slathered the exhuast studs with antisieze & installed new copper nuts. A few of the studs I couldn't get the torque wrench on, but think I got within the 15-18 pounds with a box end.
I think I'm ready to flip the motor onto the SSIs & finish up. Anything I should check/do before I flip it?
Paul
Old 05-15-2011, 12:13 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #5 (permalink)
Binge User
Schrup's Avatar
I'm putting my interior together until my buddies help me turn over the engine & set it on the SSIs. I have deleted many things off the car. I can't recall this wire & am not sure what it connected to. Any help is appreciated. I can take a better pic if neccessary.
Sunroof switch maybe?
Paul
Old 05-16-2011, 03:03 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #6 (permalink)
Now Available for Ordering:   101 Projects For Your BMW 3 Series 1982-2000  [more info]
Binge User
Schrup's Avatar
Hit a snag today. The meter gasket oring I ordered is way too big. The part # is 911-110-936-01. I'll call the dealer tomorrow.
Paul
Old 05-17-2011, 07:34 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #7 (permalink)
Binge User
Schrup's Avatar
I have to wait a week for the dealer to get the $12 o-ring. I got another one from a filter place, but it's a smidge too big & I don't feel comfortable using it. I believe this tiny strainer fell out of my cold start valve. Anyone seen one?
This fitting is very loose going into my throttle body, any suggestions on how best to seal it?
Again, any help is appreciated, God knows I need it!
Paul
Old 05-19-2011, 10:56 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #8 (permalink)
The strainer basket looks like the one that goes in the delivery fitting @ the fuel dist,could also also be an outlet basket on top going to one of the injectors. I cant tell the size by looking at the photo. The 2nd fitting look like the 1 that goes in the back of the throttle housing & attaches to the brake booster hose for the suction jet.. The smooth end must be epoxyed back into the throttle housing or you will have a false air leak.
Howard
Howard Freeman
Old 05-20-2011, 04:33 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #9 (permalink)
Binge User
Schrup's Avatar
I have mock fitted my CIS on. I'm missing the throttle spring, no big. I'll need some more time to figure out the vacuum lines, the PO deleted the decel valve. This afternnon I'll pull everything back off & put gasket sealer on the intake gaskets & get them torqued down & start reassemble.
I figured out that PET is now available online, big help. I've been trying all morning to figure out where the last few pieces go, just a couple brackets, bonded rubber mounts, & a couple spacers. Any ideas?
Here's a few engine pics.
Paul
Old 05-22-2011, 12:48 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #10 (permalink)
Straight mount with rubber mounts to # 6 intake runner & rubber mounts to air box. Curved mount rubber on the mounting tab below the cold start valve on the air box & 8mm hole on the othe end mounts to the throttle belcrank mount on the engine.
Howard
Howard Freeman
Old 05-22-2011, 01:31 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #11 (permalink)
white plastic washerslook like the ones that mount between the bottom of the rocker panel & the body.
Howard
Howard Freeman
Old 05-22-2011, 01:33 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #12 (permalink)
Binge User
Schrup's Avatar
Thanks Howard, got those mounted on the airbox now. Any idea about the smallest bracket in the pic?
Paul
Old 05-22-2011, 02:05 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #13 (permalink)
Thats is a doubler for the throttle return bracket. It mounts on the throttle housing toward the air cleaner & on the #1 cylinder side. It also attaches to the spring bracket. P.S. you need 2 throttle return springs. 1 up top on that bracket & one below between the belcrank & the boss on the bottom of # 2 cylinder intake runner. 2 different part #'s.
Howard
Howard Freeman
Old 05-22-2011, 04:26 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #14 (permalink)
The defroster light power supply Black/blue & ground,brown.
H
Howard Freeman
Old 05-22-2011, 05:27 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #15 (permalink)
Wrong colours,Sorry. still the same wires. Turn the parking lights on & check for 12V's,thats you power & of course your 31 should bea ground to the chassis. Check continuity on that 2.
H.
Howard Freeman
Old 05-22-2011, 05:31 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #16 (permalink)
meter gasket o-ring?
where does that o-ring go? i have not seen an o-ring between the fuel distributor and its mounting surface.
Old 05-22-2011, 05:55 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #17 (permalink)
Binge User
Schrup's Avatar
Yes the O-ring goes between the distributor & the body, I fear I may have ordered the wrong one. I'll order a new one along with whatever else I need in the morning. This last bracket is giving me fits. I appear to be missing both springs & the spring bracket.
I saw a picture with the TPS attached in the classifieds, I honestly don't remember pulling off the motor or seeing it floating around. Any chance it wasn't there to begin with? Hopefully I can get another from the classifieds.
Paul
Old 05-22-2011, 06:39 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #18 (permalink)
o-ring
i thought that only turbo charged cis distributors had an o-ring under them
Old 05-22-2011, 07:07 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #19 (permalink)
All Cis car have that oring,if it missing you will introduce false air into the system.
Howard Freeman
Old 05-23-2011, 05:49 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #20 (permalink)
Copyright ©2000 - 2013, vBulletin Solutions, Inc.
Copyright 2011 Pelican Parts - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
