PeteM1965's Avatar
Bosch CDI Wiring Help
Well Perma-tune refuses to function when hot, so I'm ready to replace. Now I have a question about wiring.
The car is a 68, engine is a 69S with Webers, but the Perma-tune has a circular 6 prong connector. I have a rebuilt Bosch 3-pin CDI that I would like to replace the Perma-tune with.
1. Why would a 69 have a 6-pin connector? The car has points in the dizzy. What are the extra wires running?
2. Can I revert this back to a 3-pin setup?
If anybody can help I'd appreciate it.
Old 06-08-2011, 05:06 PM
356RS's Avatar
Yes you can revert back to the Bosch CDI. The wiring from the CDI should be: A, goes to the #15 of the coil. B, is the 12 volt input for the CDI. C, goes to the distributor points. D is ground.
Mark Jung
Bend, OR
MFI Werks.com
Old 06-08-2011, 05:43 PM
HawgRyder's Avatar
Send a message via ICQ to HawgRyder
A 69 uses a 3 pin connector.
Bob
Bob Hutson
Old 06-08-2011, 05:53 PM
RETIRED
Joe Bob's Avatar
Talk to Ingo... 3.6@cox.net
2012 ML350 3.0 Turbo Diesel
Old 06-08-2011, 05:57 PM
ischmitz's Avatar
Send a message via Skype™ to ischmitz
Hi Pete,
I got your email and I think the answers from Mark pretty much cover it. If the distributor has its stock points you can only use a 3-pin Bosch CDI. The later 6-pin Bosch box will not work since they expect a VR sensor signal instead of points. Maybe the Permatune has some sort of setting where the 6-pin version works with either points (early car) or VR sensor signals (SC) not sure.
On the 3-pin Bosch the middle terminal is switched +12V from the ignition, the housing terminal is GND. Terminal A goes to the coil and terminal C goes to the points. As soon as terminal C is shorted to GND the box should release a spark.
Good luck,
Ingo
1974 Targa 3.6, 2001 C4 (sold), 2019 GT3RS, 2000 ML430
I repair/rebuild Bosch CDI Boxes and Porsche Motronic DMEs
Porsche "Hammer" or Porsche PST2, PIWIS III - I can help!!
How about a NoBadDays DualChip for 964 or '95 993
Old 06-08-2011, 09:23 PM
PeteM1965's Avatar
Thank you to all!
Old 06-09-2011, 03:41 AM
